  • Page:
  • 1
  • 2
I have a kz650 engine and I need wiring help 05 Dec 2016 16:13 #749564
  • studerman1
  • studerman1's Avatar Topic Author
  • Thank you received: 0
Welcome everybody
I have the engine igniter and 2 coils
I would like to run this outside of the bike, but don't know how to wire them.
and also where is the shift pedal located on these?
Thanks
I have a kz650 engine and I need wiring help 05 Dec 2016 16:36 #749573
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Gonna need more info than that.
What year engine?
What igniter? Do you have a picture?
What pickups do you have?
What resistance coils do you have?
The shifter is on the left side of the motor, like 99% of all Jap bikes from that era.
I have a kz650 engine and I need wiring help 05 Dec 2016 16:54 #749575
  • Thank you received: 2829
You have the engine, but what about everything else? You say you want to run it "outside of the bike" - are you trying to make the engine run without it being mounted in a frame? :blink: Ed
I have a kz650 engine and I need wiring help 05 Dec 2016 17:21 #749577
  • studerman1
Using the motor for a custom go-kart. I bought it off a friend who had it as a backup motor.
No idea what year it is
Also How much is a kz650 motor worth?
Attachment 20161205_191015.jpg not found
Attachment 20161205_191143.jpg not found
Attachment 20161205_191152.jpg not found
Attachment 20161205_191158.jpg not found
Attachment 20161205_191412.jpg not found
Last edit: by studerman1.
I have a kz650 engine and I need wiring help 05 Dec 2016 18:54 #749589
  • rstnick
  • rstnick's Avatar
  • Thank you received: 374
This should help:
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
The following user(s) said Thank You: Nessism, studerman1
I have a kz650 engine and I need wiring help 05 Dec 2016 20:14 #749593
  • studerman1
Thanks, also which one is the positive terminal on the coils?
Attachment 20161205_191015-2.jpg not found
I have a kz650 engine and I need wiring help 05 Dec 2016 21:32 #749605
  • azman857
  • azman857's Avatar
  • Thank you received: 111
There is no + or - on coils.
I have a kz650 engine and I need wiring help 05 Dec 2016 21:56 #749607
  • loudhvx
  • loudhvx's Avatar
Some Kz coils are marked with a + and -, but it shouldn't matter which is which, so there is not really a reason to have them marked. On single output coils there may be a small benefit to having the polarity a certain way at the plug, but that does not apply on waste-spark systems. Just for uniformity, I put the red wire to the + terminal.
The motor looks to be a later motor since it has the valve cover ports, which you should cap off. They are not vents, they are emissions related. The little rubber pipe coming off the transmission is the crankcase vent, which should be left open, with a hose or filter.
The valve cover seems to have a bulge for an idler pulley on the camchain, so it is a roller-camchain motor. So maybe it's somewhere from 1979 to 1982. The vin number can be used to get it more precise.
The coils (primary) should measure somewhere between 2.3 and 2.7 ohms. Points coils would measure around 4 ohms. Those coils in the photos look like the later electronic ignition coils.
That igniter looks to be one from the first year of igniters.
Last edit: by loudhvx.
I have a kz650 engine and I need wiring help 05 Dec 2016 22:02 #749608
  • azman857
  • azman857's Avatar
That bulge in the center of the cover holds a rubber chain guide. All '80 and later KZ 650 used the hyvo cam chain. No kickstarter is the other clue.
I have a kz650 engine and I need wiring help 06 Dec 2016 05:12 #749629
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1623
Since it doesn't have a kick starter, it's probably from an 81 or 82 KZ650-CSR. The shift pedal shaft is directly below the sprocket in the 4th pic --- it has a splined end. There is also a clutch pushrod & shift rod nearby. Do not pull out the shift rod, as it holds the shift forks which will fall down & they are difficult to re-install. Parts diagrams. Partzilla. 1981 KZ650-H1.
Voltage regulator. If you need a reg-rec, you can use one from a late model Ninja 500 or Vulcan 500 (credit to loudhvx).
good condition units can be found on eebbaayy for pretty cheap. or you could use a mosfet reg-rec.
Ignition coils n stuff. you can use Dyna ignition coils. either the grey 2.2 ohm (closest match to stock) or the green 3.0 ohm which are also used with the Dyna S ignition system. Related, be sure to clean, check & lubricate the timing advancer under the pulsing coil plate. When turning the crankshaft, use a 17mm wrench on the big nut (not the smaller/inner 14mm advancer bolt).
Kawasaki service manual. jarlef z650 . the 1981 KZ650 pdf manual is in the Files section. w color wiring diagram.
KZ650-H1. KZ650-CSR.
Last edit: by martin_csr.
I have a kz650 engine and I need wiring help 06 Dec 2016 06:59 #749642
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
That thing is gonna be a blast...... if you get it built please share it with us....... I remember a go cart that used to run at Byron drag strip that ran a 650 BSA or a Trumpet motor ran 13s at 100 and always wanted one.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
I have a kz650 engine and I need wiring help 06 Dec 2016 08:40 #749652
  • loudhvx
  • loudhvx's Avatar
azman857 wrote: That bulge in the center of the cover holds a rubber chain guide. All '80 and later KZ 650 used the hyvo cam chain. No kickstarter is the other clue.
Thanks... never noticed the bulge on the later covers.
Doesn't the roller chain cover have the same bulge? I thought I remember seeing it on the early 650's.
The 550 hyvo covers don't have that bulge.
Maybe Kaw just didn't bother changing the casting.
  • Page:
  • 1
  • 2
