Finally got time today to work on the lighting issue and the relay that was making an audible buzz and was vibrating.
I think I figured out why the wiring diagram doesn't show the "LIGHTS', 'MAIN' and 'START' relays. These silver barrel-shaped relays plug into the 'junction box' as it is labeled in the wiring diagram. Here again is a photo of this 'junction box' -- I've previously been calling it the 'fuse and relay panel' - the wiring diagram is calling it a 'junction box'. I discovered that by looking at the wire colors plugged in to the back side of the panel, then tried to match the number and color of wires to the wiring diagram, and found that this fuse and relay panel is called the 'junction box':
Well notice all the fuses. Those fuses are *not* on the wiring diagram either.
I'm guessing that Kawasaki just considers the fuses and the three silver relays as part of the 'junction box' component and that's why the relays and the fuses are not shown on the wiring diagram, which is here:
FIRST, this is how I solved the mysterious 'audible buzzing' and vibrating 'LIGHTS' relay I have mentioned earlier in this thread.
I found a bad connection to the "Turn signal control unit" (left side of the wiring diagram). I unplugged that compromised, dilapidated connector. THE FREAKING TURN SIGNALS STILL WORK FINE. And so do the 'HAZARD' flashers. So that little f_cker is out of there.
I covered the connector to keep it clean and dry. I'm stumped as to what the "Turn signal control unit does" since it has no obvious effect on the turn signals or Hazard flashers. Maybe this bike came with 'self-canceling turn signals' ? Not sure.
By unplugging the bad connector to that turn signal unit, it must have removed a short in the circuit somewhere because NONE of the relays make any audible "bzzzzz' sound, nor do they vibrate any more.
THE HEADLIGHTS NOT WORKING ISSUE
Here's what my multimeter told me this afternoon:
1) the "R/L" (Red and bLue) wire provides power from the junction box to the reserve lighting unit
2) and that wire does not show voltage until *after* you push the start button
3) that means that "LIGHTS" relay (on the junction box) does not switch on until AFTER the 'MAIN' silver relay is triggered by pushing the start button
4) in other words, this model is set up to NOT TURN LIGHTS ON until after the start button is pushed (I have noticed that the Kaw VN-750 Vulcan model does the same thing).
So I started the bike and found that the 12vdc *is getting to the Reserve Lighting Unit.*
Notice that the Reserve Lighting unit (left side of diagram) then pipes power down to the Dimmer switch (HI beam/Low beam switch on the left side of the handlebar. And that switch then pipes voltage to the headlight (at least when the RLU module is working).
So there is NO VOLTAGE AT ALL coming out of that Reserve Lighting Unit (RLU). It gets input voltage FINE. But never supplies power out to the Hi/Low Beam dimmer switch on the left handlebar.
I verified that the RLU's ground wire (black/yellow) is providing a good ground.
The only other wires coming out of the RLU are:
- "Lg/R" (light green/red) -- no voltage ever
- "L/Y" (bLue and Yellow) -- no voltage ever
- "L/O" (bLue and Orange) -- nada, nothing
- "R/B" (red and black) -- never any voltage
Power comes IN fine to the RLU on the R/L red/blue wire after pushing the start button. And the ground to the RLU is good. But it never spits out any voltage to the Hi/Low Beam dimmer switch.
It also explains why the "Hi Beam" lamp on the dashboard never lights up -- that lamp is powered by the RLU.
And it explains why the headlight socket never has any power.
So I do not want to replace the RLU. I want to bypass it.
Anyone see a way to do that? I need to get power to the hi/lo beam switch on the handlebar and to the 'Hi Beam" lamp on the dashboard when the high beam is on.
