Hi Redhawk, yeah you're right about the pickup coil or trigger coil as it's also referred to. It's been a while since I've had a chance to get back to this little gem.
It's been rattling around in the back of my head since I began asking questions. I ordered online what I thought was a manual that had info on this model but it was the wrong manual and therefore wasn't much use.
I recently began digging into this once again. I think I've ordered an original kawasaki (but reproduction under copy right) manual for this model.
Interestingly enough it seems there was some sort of changeover between year model 1981 to 1982 when they seemed to have changed the ignition somewhat and how exactly I'm not exactly sure but according to my source in obtaining this manual they seemed to think that there was some sort of crossover where the information on ignition was sketchy.
My particular bike year model on VIN sticker on bike shows a 12/81 which on the title/ownership its listed as a 1982, and in brackets under the VIN (KS250M).
On the back of the manual I ordered is listed 1982 KZ250-M1.
My source also seemed to think that in the KL 250 manual which they checked there was one page listing some info on a CDI module but nothing else in the index or table of contents. The manual I got my information to order my copy was from a picture of front and back showing the part number which my local bike shop had in his library. It too didn't list anything about a CDI moduel but had wiring for some 250 models which illustrated in the schematic an "igition unit" not sue if that's considered the CDI module er not, but we're going from there with that once I get the time and receive the manual to start from scratch again.
When I began this adventure I had this schematic from the bike shop manual and was attempting to check stuff and had ordered a used (was stated online sales that it was from a working bike) CDI module. I hooked it up and still no spark, so began asking questions at my local bike shop and was told to check resistance of this pickup coil which i did and ended up buying his replacement installed that still no spark. I then began tracing wiring and CDI pinout and ended up removing wires from plug carefully in an attempt to verify wiring was correct. Srill no spark up to that point and that's where it got left.
I had current to the coils when I began before disturbing anything with the used CDI so...
This time I've ordered a brand new replacement (supposedly for this model bike) and am currently awaiting it's arrival.
I'll begin with a new one this time maybe even replace old pickup coil too, as I'm concerned about the alignment of said replacement coil I was sold no elongated holes for alignment (none with the original either but think it was closer to pickup magnet on stator?
I'm also concerned about the key switch might be the culprit as it doesn't appear damaged in any functional way but it doesn't seem to have a definitive click from off to on but neutral light comes on and current is going to coils.
Hopefully with new CDI module. some research and investigation on reconnecting wires to CDI plug, checking pickup coil again I might get some fire this time around?
Sorry for the book but it's been a while since I've been on and gathering more information on this.
