1981 CSR650 Keycode
  • xxsierraxx
  • xxsierraxx's Avatar Topic Author
1981 CSR650 Keycode
17 Jul 2015 13:47
#681390
Hey Guys,
Just picked up a nice little '81 CSR650. I got papers for it but unfortunately there is no key. I have read you can get the code off the ignition but I have removed the whole mechanism and cannot see a key code. On that year bike, where else might I look?
Thanks
1979 KZ1000
1981 CSR 650
Honda "cough"
  • martin_csr
  • martin_csr's Avatar
Re: 1981 CSR650 Keycode
17 Jul 2015 14:14 - 18 Jul 2015 06:10
#681394
1981 KZ650-CSR code location: ign switch, seat lock & helmet lock (photo). Example code: Z5064.
After determining the code, one source for replacement keys is eebbaayy: try searching the key number --- I did the other day & found a seller who cuts new keys using the code you provide.
2 Kawasaki Motorcycle Keys Code Cut Z5601 thru Z5650
Last edit: 18 Jul 2015 06:10 by martin_csr.
The following user(s) said Thank You: xxsierraxx
17 Jul 2015 14:15
#681395
Look next to the keyhole on each of the locks. On mine, there only is a code on the seat lock. Mine is a 1977; later models may have the codes in different places on the locks. Ed
17 Jul 2015 17:20
#681415
  • xxsierraxx
17 Jul 2015 19:13
#681434
The code i found there makes no sense. It reads 008-2bON. I can't seem to find any mention of that code.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • martin_csr
18 Jul 2015 06:07 - 18 Jul 2015 06:29
#681469
You may have to take the ign switch to a locksmith. It's possible it isn't original & could be aftermarket. ???
Did you try cleaning the switch where the code is supposed to be? (the code in the pic is upside down)
The seat lock & helmet lock are your other options, but the seat needs to be open to remove them. pretty sure.
Last edit: 18 Jul 2015 06:29 by martin_csr.
  • xxsierraxx
18 Jul 2015 08:06
#681489
I got the seat lock off and found the number N01. That appears to make more sense.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • martin_csr
18 Jul 2015 12:05
#681519
How so?
  • xxsierraxx
19 Jul 2015 07:57
#681619
When I google that number I get some results. Found one on eBay, in UK though so it's 20 bucks.
1979 KZ1000
1981 CSR 650
Honda "cough"
  • martin_csr
19 Jul 2015 09:10 - 19 Jul 2015 12:48
#681633
never mind.
Last edit: 19 Jul 2015 12:48 by martin_csr.
  • xxsierraxx
19 Jul 2015 09:50
#681639
Actually, after a little more cleaning and searching I found the code Z5683. From what I've read that's the number I'm looking for. Any recommendations on someone in Canada or US who cuts keys for these?
1979 KZ1000
1981 CSR 650
Honda "cough"
19 Jul 2015 14:43
#681666
xxsierraxx wrote: Actually, after a little more cleaning and searching I found the code Z5683. From what I've read that's the number I'm looking for. Any recommendations on someone in Canada or US who cuts keys for these?
KZr member rstnick
See my earlier post.
Good Fortune! :)
