The short story is that I did the WG coil mod in addition to some other things on the bike and when I put it back together I have zero spark.
Thanks to Bill in the
"Another reason to do the coil Mod anyway"
thread, I know that the WG mod was done correctly and is not causing the problem.
So, I started going through the troubleshooting steps in the FSM for ignition trouble. I did all of them that I could do with a multimeter. I had to skip the ones that required the Electrotester because I don't have one.
The pick up coil resistance test should result in a reading between 360~540 Ohms when connected to the leads.
The readings are within tolerances. One is 406 & the other is 424 Ohms. I concluded the pick up coils are good.
Next test was the Wiring Inspection test where you find out what the voltages are at the IC Igniter leads & Pick-Up Coil leads. The negative is connected to ground and the positive is put on the various wires. (This is done while the ignition & run switch are both ON.)
According to the FSM I should have full battery voltage on the 4-pin connector for the ignition coils at the Yellow/Red, Black, or Green wires.
The reading came out correct for Black and Green showing full batter voltage. The other two connections show 3.2 mV. But that makes sense because I did the WG Coil Mod and am now bypassing the Yellow/Red wire anyway...right?
At the 4pin connector for the pick-up coils I should have between 0.5~1.0 V on the Black, Blue, Yellow, or Red.
I got a reading of 3.8 mV (small 'm') at each of those connections. 3.8mV would = 0.38V, correct? If so, there is a possible problem at this point since it is 0.12V lower than the minimum required reading.
The last test I could do was the IC Igniter Resistance test. For this test, I disconnected both of the above 4 pin connectors. Again, according to the FSM I should get the following:
At the 4-pin connector for the ignition coils I should get an infinity reading when Black/Yellow is on + and Black, Green is on - when the meter Range is set to 1 k Ohm. I get an infinity reading (O.F) so I know this is good.
The remaining tests on the ignition coil connector are supposed to be in the 100 Ohm range and show readings between 200~700 Ohms depending on which of the 3 combinations you are doing. For two of these readings I get 0.986 k (Ohms 986 Ohms) which is significantly higher than tolerances. and the other two I get a reading of O.F (Overflow). Seems like a problem...
I then did the required test at the 4-pin connector for the pick-up coils. The Meter Range is supposed to be in the k Ohm range and for each test I should show a reading of between 20~45 k Ohms depending on the combination.
For both of these I get a reading of O.F (Overflow). Again, significantly higher than tolerances. So, it looks like an IC Igniter problem. Could this possibly explain the low voltages I saw when checking the pick-up coil voltage earlier?
So, bad IC Igniter? I don't want to buy another one just to find out I'm wrong so can anyone confirm this for me? Do these things go bad frequently or is it just a fluke that mine did?
Thanks for reading this beast of a post.
EDIT: New info
Post edited by: Little B, at: 2008/02/17 19:01
