ok, next question.. I have an ic igniter with 2 seperate connectors coming off of it. One connector, the bottom one, is right and connected to the new harness. the top connector is a female 4 pin with 4 wires going into it, blk, blk/ylw, grn, ylw,red. The only connector i found on the new harness is also a female, with 5 wires going into it. 2 wires go into one slot, a blk/ylw and a ylw/red, the rest are ylw/red, grn, blk. Im thinking i just have to individually make new connectors for each wire, and splice the 2 wires off the harness, the blk/ylw and ylw/red into one connector, then the rest as is, correct? Is this a gpz ingniter? is that why i have 2 connectors the same that are supposed to plug into each other?
