  • Page:
  • 1
650 wouldn't start because kill button was broken inside 05 Jul 2007 20:57 #154990
  • old650
  • old650's Avatar Topic Author
  • Thank you received: 0
My kill swirch (off/run/off) on the throttle grip housing was always a bit loose and sloppy but didn't really give me much trouble, until yesterday. I came back to a parking lot and the bike would not start, no way, no how. No button, no kick. I had idiot lights/headlight/signals and a good main fuse. I took the tank and side covers off in the lot and could not find any bad/loose connections. What the hell? I got the bike home and took off the kill switch for an inspection. I seperated the housing and removed three tiny screws holding the switch button. It fell apart in my hand ! The button was busted up into about three chunks inside. I took one off my parts wreck, cleaned it up, lubed it inside, then remounted the works. It went Vroooooom off the starter button.:) Oh ya, while I was in the housing I sprayed the starter button contacts with evaporating brake disc cleaner.....I found the inside of these kill switches to be: full off dirt/rusted/in dire need of spray lube.
1977 KZ 650 B1
650 wouldn't start because kill button was broken inside 06 Jul 2007 02:02 #155004
  • JR
  • JR's Avatar
  • Thank you received: 436
Sounds familiar :laugh: Pretty much the same thing has happened to me in the past except that when I took mine apart it was a squashed bug across the contacts that had caused the failure . Ever since then I try not to use the kill switch as they do seem fragile and if it works I leave it alone.
Glad you got it going.
650 wouldn't start because kill button was broken inside 06 Jul 2007 06:40 #155060
  • bill_wilcox100
  • bill_wilcox100's Avatar
  • Thank you received: 5
I had a Kill Switch failure too! Mine fell apart into several pieces. Since I had no spare unit to turn to I had to rebuild it with the original bits and pieces and plastic plumbing glue. Although it works fine now, like JR I just don't use it.
Just a thought... if you have this typical aging fault, your connectors may be doing the same thing. Have you considered the Coil Re-powering modification? I did it an what a difference. Again, just a thought.
By the way, it considered real friendly here to include your location in your signature.
Best of success!
Post edited by: bill_wilcox100, at: 2007/07/06 09:43
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
650 wouldn't start because kill button was broken inside 06 Jul 2007 07:37 #155070
  • Snakebyte
  • Snakebyte's Avatar
  • Thank you received: 1
WD40 works good for this;)
650 wouldn't start because kill button was broken inside 06 Jul 2007 08:51 #155082
  • old650
Yup JR, I have the same philosophy, leave that button alone. Only time I have to turn it is when it gets bumped out of alignment somehow.
650 wouldn't start because kill button was broken inside 06 Jul 2007 09:00 #155087
  • old650
Best of success!<br><br>Post edited by: bill_wilcox100, at: 2007/07/06 09:43
I've had the coil re-powering components collected and sitting in a box somewhere. I am admittedly a little lazy at times.
:lol:
Same goes with location sig. I have been around this board for years Bill and I know the drill buddy.;)
650 wouldn't start because kill button was broken inside 06 Jul 2007 09:03 #155092
  • old650
That's what I squirted into the old/new button.:) It was unreal how much dirt was packed in that switch! 30 years worth I suppose. 1977 KZ 650 B1.
650 wouldn't start because kill button was broken inside 06 Jul 2007 19:35 #155199
  • rstnick
  • rstnick's Avatar
  • Thank you received: 376
I do not use my Kill Switch, for about a year now, since I've read these posts about kill switch problems.
My turn signal switch started getting difficult to use. Very hard to move back and forth.
When I got home, I opened both handlebar switches and sprayed them with an electrical contact cleaner, then WD40. Works like a charm now.
I will keep an eye on them because WD40 will dry out over time.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
650 wouldn't start because kill button was broken inside 06 Jul 2007 20:08 #155210
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 239
There's no reason to ever use the kill switch. Mine went bad because of my girlfriends 10 yr old son that pretty much destroys everything his hands get near. Saw the switch and just had to play with it and 10 seconds later, broken switch. Just wire across it and eliminate it.
650 wouldn't start because kill button was broken inside 09 Jul 2007 12:34 #155698
  • H2RICK
  • H2RICK's Avatar
  • Is this a fun bike, or what!!!
If you're absolutely mad to have the kill switch in place or need bits for it, brand y uses the same setup on many of their early '80's four cylinder slugs. I believe/believe all the bits are interchangeable but you may want to do some invstigation first.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
  • Page:
  • 1
