Patton wrote:
Austinroots wrote:
Just to clarify, I'm trying to find out what airbox will work for a 77 kz1000. Will the 80's model boxes work? and whats with the tube in the front of these boxes?
Here's the 1977 KZ1000-A1 air box (See next post for later model airbox with the air tube fitting which doesn't show in the FSM covering 1979 KZ1000-A1, but is shown in kawasaki.com for 1979 KZ1000-A1A, which might be a California model or a mid-year design change toward emission reductions).
And here's the airbox shown in kawasaki.com for 1979 KZ1000-A1A with the air tube fitting (which doesn't show in the FSM covering 1979 KZ1000-A1).
Having not actually attempted the interchange, am unable to provide a more responsive answer to the question. But am guessing the later model with air tube fitting would readily interchange, with the airhose fitting being simply capped off at the airbox.
The "S" shaped crankcase breather hose is believed the same on both airbox versions, connected to an outlet from bottom of air box.
Could play it safe of course and wait for the "correct" airbox without any airtube fitting.
Good Luck!
