- Thank you received: 27
Keihin carb floats / bowls / slides x2
- havakaw
27 Apr 2024 12:57 - 27 Apr 2024 12:59 #898166
by havakaw
'80 KZ 750 LTD-H
'82 KZ 1100 A-2 Shafty (ex-bagger)
Keihin carb floats / bowls / slides x2 was created by havakaw
These are two sets of Keihin carb floats & bowles & slides & springs. The needles are different. One size is larger ( thicker not as tapered) as the other size. Neither set of slides appear to have been drilled. 2 sets of springs. 1 tall and loose, 1 short and tight. Comes with a box of brass internal jets and stuff. Thank you.
'80 KZ 750 LTD-H
Last edit: 27 Apr 2024 12:59 by havakaw. Reason: Edit post
- havakaw
01 May 2024 07:53 #898288
by havakaw
'80 KZ 750 LTD-H
Replied by havakaw on topic Keihin carb floats / bowls / slides x2
These will go with the CV 32s I have. The carbs are from an 83 LTD kz750 shaft drive. I think 1 year only model. But with only 2 internal jets and the 2 different springs and slide needles, these should be pretty adjustable. These parts and the carbs shipped to your house thru the USPS $200. Thank you.
'80 KZ 750 LTD-H
