Cam caps
- rustedcutlery
Thanks, rusted
- Thank you received: 2829
- rustedcutlery
- Motor Head
- Thank you received: 391
650ed is spot on, that Feebay seller is not doing anyone any good. I see them listed all of the time without the Caps, then the same seller is also listing the caps separately. These guy's are Breakers not mechanics, they think they can get more money by selling separately. :blink:650ed wrote: You should contact the seller and see if he can possibly find the cam caps. The journal for the cam in the cam caps and head are machined together, so using caps from another head may lead to problems. I'm not saying it cannot be done, but if possible always keep the head and caps together.
- BlackZ1R
- Kawasaki in my blood
- Thank you received: 47
There is a guy on here that just sold a J head without caps. He has several heads for sale without caps, says he has a pile of caps to go with them. Was it a guy from here?
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- rustedcutlery
Edit: I just sent the seller a message stating my concerns about the caps. The seller's name is kzchoppers2011 on eBay. Maybe someone knows him?
- rustedcutlery
- Motor Head
- Powerstroke_fan
- Thank you received: 83
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- rustedcutlery
Secondly, I think aslong as I can find a set of cam caps, and get them line bored, I should be fine. I know this happens a lot with automotive engine blocks.
- Thank you received: 2098
www.kzrider.com/forum/23-for-sale/504030-cylinder-heads#504204
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
