Yoshi stage 1 kzj/r cams
  • s1elr
  • s1elr's Avatar Topic Author
  • blood runs green
05 Feb 2012 06:06
#502171
Hello all, I hope you can help with a few questions.
I have a set of 80's cams from my Kz1000r I had installed
and can't find any specs on them.They are marked with POPY and lr1/lr2
Neither has any tack groves, and I only have a slide caliper.
Any help would be great.
Ty, steve
  • LarryC
  • LarryC's Avatar
Re: Yoshi stage 1 kzj/r cams
05 Feb 2012 08:34 - 05 Feb 2012 08:37
#502176
Sounds like either you have 2 intake cams or they're made for a J motor. Does your 1000R have an electric tach?
Measure the overall height of the lobe. The width of the base circle and subtract the base circle. You'll have gross lift number but no duration.
Duration is difficult to compare cams by most of the time because it was measured at different checking lifts.
Someone here may well have an old sheet for those cams. If you can't find anything, try an email to Yosh
Larry C.
Last edit: 05 Feb 2012 08:37 by LarryC.
The following user(s) said Thank You: s1elr
  • joe k
  • joe k's Avatar
07 Feb 2012 00:35
#502472
Hope this helps you mate
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
18 Feb 2012 21:39
#504929
joe k wrote: Hope this helps you mate
Joe, would you mind emailing that page to me? mmsmithgall[at]gmail[dot]com
Researching as much Yosh stuff as I can find...
2000 ZRX 1100
1976 KZ 900- Daily Driver
