Starter clutch issues to check?
  • gane
  • gane's Avatar
Re: Starter clutch issues to check?
25 Feb 2011 12:16 - 25 Feb 2011 12:21
#433371
A quick tip,, The "idler gear" which is the inner componant of the starter clutch "sprag" often develops "waves" on the face which the rollers engage. if there is any dicernable wear there, replace as well as rollers & springs (3 each). luck G . PS, In reading, your' stator bolt is discontinued. if in your' searches you see one, nab it..G
[img][/img] 1977 KZ1000A1
Last edit: 25 Feb 2011 12:21 by gane.
  • bgmrc
  • bgmrc's Avatar Topic Author
25 Feb 2011 12:49 - 25 Feb 2011 12:59
#433387
good avice bros....
thanks!
i have my KZ up on my cycle stand(260bux at harbor freight) best purchase i have made in a long time...anyway so the oil still leaks pretty well when cover is removed...bout a half QT still leaks and i straped down and CENTERED...
so ill pull the left cover off this weekend and see what it all looks like..and pop that flywheel
ill look for the oil filter also...and hit up Z1 next week for parts needed
thanx all
Last edit: 25 Feb 2011 12:59 by bgmrc.
  • Rainman
  • Rainman's Avatar
  • and a little Kaw shall lead them
25 Feb 2011 17:35 - 25 Feb 2011 17:48
#433445
The left hand thread bolt threads into the end of the crankshaft and the flanged head holds the flywheel/rotor onto the taper on the crankshaft (click on picture to enlarge)
The larger diameter threads in the end of the flywheel/rotor are right hand and are the same size (at least on the 79 750 twin) as the rear axle.
The oil filter is under the finned cover at the top right.
80 KZ750 H1 - the Kaw calf
79 KZ750 Twin - Miss Nov 2008 KZR calander
79 KZ750 Twin parts bike
78 KZ650 C2 Parts Bike
75 KZ400 Wife's old bike sold
81 KZ440 A2 LTD Wife's new bike
84 Honda 450 Rebel Wife's newest bike
Jim
Quincy,IL
Last edit: 25 Feb 2011 17:48 by Rainman.
  • Rainman
  • Rainman's Avatar
25 Feb 2011 17:46 - 25 Feb 2011 17:47
#433446
The axle installed and one way of holding the flywheel/rotor for removal. Resists clockwise rotation.
When tightening the LH thread bolt, the end of the screwdriver goes to the bottom of the flywheel/rotor. Resists counter-clockwise rotation.
Good luck,
Jim
Jim
Quincy,IL
Last edit: 25 Feb 2011 17:47 by Rainman.
  • calebstrawn
  • calebstrawn's Avatar
07 May 2014 11:07
#631673
Hi all,
I've had starter issues: the typical can of rocks noise, and the starter only engaging some of the time, etc. so I was convinced it was my starter clutch. Now that I've pulled the clutch and inspected it, I don't see any major issues or differences to the brand new one I bought. Can a starter clutch be bad without having any physical damage visible? I'm going to put the new one in for good measure, but I'm concerned that I may not solve the issue, and would have to crack open the bottom end again to find the real problem. I'd rather get it right the first time, and get riding... Any thoughts? Thanks.
85 ZN700 LTD Shaft
  • KZQ
  • KZQ's Avatar
  • Administrator
  • Administrator
07 May 2014 11:25
#631680
Hi Caleb,
Look very closely at the springs and cups that push the rollers against the boss. Chances are that one or more is worn/chipped/cracked or crushed. Generally replacing the rollers, springs and cups will get the clutch working again, although to work as good as new the boss/ sprocket needs to be replaced also.
Good Luck
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
07 May 2014 12:08
#631683
Take a look at the starter clutch diagram below. Are there any pieces in that diagram that you do NOT plan to replace? Ed
Attachment 00011_2014-05-07.jpg not found
  • JimB
  • JimB's Avatar
07 May 2014 12:58
#631685
Look at the spring lengths. Most likely if there is no noticable physical damage the springs are loose and not applying the same force to engage the clutch. When I replaced mine they were a little bit shorter but compressed easier.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • calebstrawn
07 May 2014 20:59
#631752
Yeah, I pulled the springs out of the old clutch and they seem weaker than the new ones. Hopefully this does the trick. I did notice a bit of slack or wiggle between the inner and outer coupling where the main chain drives the secondary shaft. Is it normal to have a little play (2mm of travel) here? Or should I go ahead and order new rubber dampers? I appreciate the quick responses. I'm pretty new to working on bikes, thanks for your patience.
85 ZN700 LTD Shaft
08 May 2014 05:44
#631795
  • calebstrawn
08 May 2014 08:27
#631806
Thanks, Ed. I've replaced 13193, I am not replacing 12406, the teeth show no signs of wear, it is straight and solid.
85 ZN700 LTD Shaft
08 May 2014 08:48
#631809
If is was mine and I was going through the trouble of replacing the other pieces I would also replace 12406. I suggest you at least check it VERY carefully before deciding not to replace it. It isn't the teeth that are a problem The problem is the race that the rollers engage. Take a look at the images below and notice the wear on a used part compared to the surface on a new old stock part. Those ridges on the surface of the used part cause the starter clutch to slip even with new rollers, so check to see if yours looks like the used part or the new part. Ed
Attachment 00000a_2014-05-08.jpg not found
Attachment 00000b.jpg not found
