Vintage 11/78 High Performance Article 26 Jan 2010 13:30 #344704
  • otakar
  • otakar's Avatar Topic Author
  • Thank you received: 29
I have a copy of a Cycle world 11/78 that I believe would be of maximum interest.
"Taking It To The Tens"
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Vintage 11/78 High Performance Article 26 Jan 2010 13:34 #344705
  • otakar
If there was some way that i could post the entire thing here that would be great. I scanned the entire article and have it in individual page JPG. files.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Vintage 11/78 High Performance Article 26 Jan 2010 15:51 #344746
  • Bluemeanie
  • Bluemeanie's Avatar
  • Thank you received: 14
I'd like to read it! I'll just wait here 'till it shows up.... :blink:
Last edit: by Bluemeanie.
Vintage 11/78 High Performance Article 26 Jan 2010 16:20 #344761
  • RonKZ650
  • RonKZ650's Avatar
  • Thank you received: 238
I remember the artical well. Took quite a bit of work to make a Z1R run a high ten. How times have changed.
Vintage 11/78 High Performance Article 26 Jan 2010 18:11 #344810
  • otakar
Actually it did not take much at all. I wound up copying the article with mine. I did not even bother changing the carbs like Yoshimura did in the article. I had the bike timed in Hawaii and got into the high tens regularly, even though not consistently. But I never did say I was a Pro drag racer. It is an1103 with Bonneville cams and a little bit of head work. It took a lot more with the GS1000. RC had to punch it all the way to 1200.
Now- Anyone know how I can post this article????
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Vintage 11/78 High Performance Article 26 Jan 2010 18:19 #344813
  • Kawickrice
  • Kawickrice's Avatar
  • Thank you received: 18
OMR is pretty good at posting stuff like that. If you already have it scanned you may be able to get it into a pdf format but am not 100% sure. I think there is a free pdf application you could try but cant remember the name. Try a google search for it. Good Luck, I would be interested in reading it too.
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Vintage 11/78 High Performance Article 26 Jan 2010 21:22 #344846
  • will61310
  • will61310's Avatar
  • Thank you received: 6
otakar wrote:
Actually it did not take much at all. It is an1103 with Bonneville cams and a little bit of head work. It took a lot more with the GS1000. RC had to punch it all the way to 1200.
Pops Yoshimura pulled 133 hp / 76ft lb torque on a gs1000 road racer with a stock bore, i wonder what that would relate to in the quarter mile?
...1980 LTD 1000...
Last edit: by will61310.
Vintage 11/78 High Performance Article 27 Jan 2010 07:57 #344887
  • otakar
The # do the talking. Only 76 pound /feet of torque. The two # should be much closer together. This meant that he got all of his HP up hi on the RPM band. Now- If he got 110Hp and 110 Lb/Ft of torque, that would be impressive.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Vintage 11/78 High Performance Article 27 Jan 2010 08:01 #344889
  • otakar
If someone wants a zip file of this article. send me an email to This email address is being protected from spambots. You need JavaScript enabled to view it. and I will send it to you directly. That way we can discuss it here with more objectivity.
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Vintage 11/78 High Performance Article 27 Jan 2010 08:09 #344891
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2088
If .pdf is the key to getting it posted, then it should be quite easy if you use the latest version of MSWord. All you have to do is copy the .jpgs to a Word .docx, then save as .pdf.
Vintage 11/78 High Performance Article 27 Jan 2010 08:24 #344892
  • Jack
  • Jack's Avatar
  • Thank you received: 7
A couple of superbike riders used to come to our local track Wed. night grudge races back in the day. 1015 Yosh Kawasakis they were running mid 10's going through in 3rd. gear ,maybe a little 4th., at 133-135 mph. With the front wheel in the air,road race gearing is not for the 1/4...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
Vintage 11/78 High Performance Article 27 Jan 2010 14:33 #344940
  • otakar
Well I sent out four Zips of the article so far. let me know what you think.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: by otakar.
