82 KZ750 Resto / Cafe *updated*
- Jrbrownie00
Re: 82 KZ750 Brat/Cafe **UPDATED**
18 May 2013 16:21 - 11 Aug 2014 16:30
So I'm getting closer, figured out I have a bad starter clutch for sure. It only engages in certain positions. Picking up a seat today. I keep blowing my main fuse whenever my new tail light is hooked up.
82' kz750 ltd.
Last edit: 11 Aug 2014 16:30 by Jrbrownie00.
- Jrbrownie00
Re: 82 KZ750 Resto / Cafe - First Timer
18 May 2013 22:52
:woohoo: Temporary seat but I'm really liking the direction it's going. Next I need to visit my welding friend and get a loop and make a seat pan.
82' kz750 ltd.
- Jrbrownie00
- Jrbrownie00
09 Jun 2013 00:20
Replaced my starter clutch today, will add oil and try to start it up tomorrow. The job really wasn't as difficult as everyone makes it out to be. Challenging but totally doable.
82' kz750 ltd.
- Jrbrownie00
09 Jun 2013 23:30
Fired up first time every time with the starter clutch rebuild. So happy/relieved that's out if the way. Switched to pods and pulled the air box, bike ran great with no jetting though it doesn't pull in the high end.
How does everyone feel about drilling out the vacuum slides? I'm skeptical.
82' kz750 ltd.
- Jrbrownie00
16 Aug 2013 22:54 - 21 Aug 2013 09:48Added my seat foam which still needs to be trimmed down a bit.
Made my taillight bracket and took it for a spin. Moderate comfort, still feel the big bumps pretty good but it looks killer.
Ordered Uni Pods to replace these cheap EMGO's which hopefully makes a difference like everyone says they will. Also decided to paint the tank but I'll leave that as a surprise.
82' kz750 ltd.
Last edit: 21 Aug 2013 09:48 by Jrbrownie00.
- Jrbrownie00
20 May 2014 18:20
Ok so it looks like i neglected this post for a while but here's what i've been up too. I couldn't stand the rust and faded frame paint. The engine was clean but tarnished.
Refinished the wheels
Redid the header/exhaust, painted the swing arm
Rebuilt the forks, Progressive brand fork springs and paint.
Painted the engine and triple tree.
Reassembly begins. New Progressive rear shocks mounted and battery tray cleaned up big time. Don't mind that rusty screw, it's gone now.
Here's how it sat after the winter, seat was temporary but it looked great,
With seat done
With new muffler
Complete list of modifications.
Superbike Bars / Oury Grips
Rebuilt forks with new Progressive fork springs, lowered internally 2-3"
Progressive Rear Shocks
Front Master Cylinder from a 96 ZX7
Ballistics 8cell Lithium Ion Battery
New Carb Holder, UNI Pod filter / Crank case Breather
Shinko 712 Front and Rear tire
RK 530 Chain, New Front and Rear Sprocket
Dyna Solid Core Spark Plug Wires/ New plugs
Dynojet Stage 3 Jet Kit
Detab/Smooth the frame, rear hoop, fresh paint on everything.
Cleaned or Replaced Front wheel bearing
Smaller blinkers from Dime City Cycles
Modified MAC 4-1 Exhaust
MOSFET Regulator/Rectifier from a 2008 CBR600RR
SS Bolt kit from Z1
Rebuilt Petcock
Rebuilt Starter clutch
With seat done
With new muffler
SS Bolt kit from Z1
Rebuilt Petcock
82' kz750 ltd.
- rmx1252001
20 May 2014 19:05
Wow... that turned out great! Nice job!
- Jrbrownie00
21 May 2014 07:54rmx1252001 wrote: Wow... that turned out great! Nice job!
Thanks, i'm just trying to work out a timing advancer problem now. My unit seems to be seized.
82' kz750 ltd.
- Jrbrownie00
22 May 2014 10:49
Got the timing advancer moving again. From years of neglect and no gasket on that side cover it had seized. It should finally feel like a 750 now.
82' kz750 ltd.
- Jrbrownie00
11 Aug 2014 16:38 - 11 Aug 2014 18:58
82' kz750 ltd.
Last edit: 11 Aug 2014 18:58 by Jrbrownie00.
- willburrrr2003
12 Aug 2014 09:22
Jr, I'm new hear but have to say you have done a great job on your bike! Thanks for sharing
What did you use for the paint for the engine and exhaust? Mine is looking at getting some paint here in next couple weeks, but I don't know what will last on the road well, so looking for advice and options.
Regards,
Will
Regards,
Will
Regards,
Will R.
Will R.
