82 KZ750 Resto / Cafe *updated*
- Jrbrownie00
16 Apr 2013 17:40 - 12 Aug 2014 11:28
Hello All. I've always been into cars so forums aren't new to me though bikes are. Not only is this going to be my first build it's my first bike. Exciting right?
So onto the bike, an 82 Kawasaki KZ750 LTD H3... Picked it up about 3 weeks ago with 18,270 on the clock for $540. It runs well but needs work after sitting outside for at least 8 years. The PO says he covered it but seeing all the rust makes me think otherwise.
My goals are to get it running perfect and fix everything that's wrong first. Then i would like to go for a comfortable brat look. Superbike bars, flat seat, no fenders etc. So far I've only tackled cleaning, an oil change, changed the plugs and air filter (k&n) and got the blinker and tail light working again.
There are a few things that have me stuck being a newbie and all.
-The front brakes are stuck. I dissembled the calipers and re-greased all the pins and bolts. Next step will be a brake bleed and then a caliper / MC rebuild if the bleed doesn't help. Anything I'm missing here?
-Bike sputters and doesn't produce sufficient power from about 1200-3000. I'm assuming this is a clogged jet or other carb issue. The header pipe on cylinder 3 takes longer to warm then the others so that's where I'll start, any other suggestions?
-Having issue on cold starts. It takes a long time for the starter to catch, once it catches once it''ll fire right up. Lost on this one? Starter rebuild in my near future?
Thanks for the help in advance. I'm going to try to update as much as possible!!
82' kz750 ltd.
Last edit: 12 Aug 2014 11:28 by Jrbrownie00.
- ThatGPzGuy
Re: 82 KZ750 Resto / Cafe - First Timer
16 Apr 2013 22:30Welcome.Jrbrownie00 wrote: -The front brakes are stuck. I dissembled the calipers and re-greased all the pins and bolts. Next step will be a brake bleed and then a caliper / MC rebuild if the bleed doesn't help. Anything I'm missing here?
Does the caliper piston move in the bore? If not, you'll need to take it apart and clean it. You may need to replace some seals.
For the sputter you'll need to pull the carb and clean it. Since you are doing one you might as well do them all.
The cold start issue is fairly common. It sounds like the starter clutch has had it. Not an impossible fix but you'll be taking the engine out to get at it. Do a search on the forum. A lot of us have tackled that particular gremlin.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Jrbrownie00
16 Apr 2013 22:42
I bought the parts for the carb refresh today, hopefully that will be that. The pistons moved when pressed with pliers. I may take them apart for a good cleaning anyway.
I have already done the research on the starter clutch, i was really hoping there was a different answer! :ohmy:
82' kz750 ltd.
- Nebr_Rex
16 Apr 2013 23:54
No.1 get a repair manual for that bike.
No.2 DynoJet still sells a jet kit for that bike.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Jrbrownie00
17 Apr 2013 13:11
I ordered a Haynes manual and am patiently awaiting it's arrival. For $25 it seems well worth it.
82' kz750 ltd.
17 Apr 2013 13:27
You would have been better off to order a Kawasaki Service Manual (FSM), and you still should do so. Haynes and Clymer manuals are not as complete as the FSM. Ed
- ThatGPzGuy
17 Apr 2013 19:20Jrbrownie00 wrote: I have already done the research on the starter clutch, i was really hoping there was a different answer! :ohmy:
So do all that live to see such times...but that is not for them to decide...
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Revboyz
18 Apr 2013 04:15
Welcome,
Take your time. There are a lot of good ideas and plenty of people that know their stuff on thiis site. Keep us postd. I have to work on mine also.
Be well...
Be well...
Why leave well enough alone!
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
Tweak it!
Have 84' kz 700
Had 96' zr6
Had 06' zzr600
- Jrbrownie00
22 Apr 2013 13:10
Making progress, with school and work I haven't been able to give it my full attention. Wire brushed, removed, sand blasted (have one at work) and this was after one coat of POR-15.
Carbs and petcock are out. Replacing the float bowl gaskets/float needles and rebuilding the petcock even though I'm not sure it needed it.
82' kz750 ltd.
- popssss
- Bikes, Babes, Pizza with everything
23 Apr 2013 00:50
which type of wheel are you going to use? spoked or Mag?
If you'd rather go with Spoked, then maybe we could switch.
how do you like the POR-15?
love bikes, and anything with a engine/motor, and i love the ride way more than the destination, unless I have a passenger, then that's all that matters.
- Jrbrownie00
23 Apr 2013 09:07popssss wrote: which type of wheel are you going to use? spoked or Mag?
I was just going to go with the mags because it's what I've got. Where are you located?
The heads aren't on the bike yet but it seems pretty good. The real test will be durability. It's easy to apply.
82' kz750 ltd.
- Jrbrownie00
28 Apr 2013 23:14 - 28 Apr 2013 23:17more progress!!
Does anyone know how to make the front blinkers work with a blinker that only has 2 leads?
82' kz750 ltd.
Last edit: 28 Apr 2013 23:17 by Jrbrownie00.
