My son's '84 Gpz build
- KzJim
Steve.. I'm everywhere...LOL How's the twin coming?
Naiveté in grownups is often charming, but when coupled with vanity, it is indistinguishable from stupidity.
Tis better to remain silent and thought a fool - than to speak up and remove all doubt.
Did ever think that maybe you've been doing it wrong all these years?
- Mine20
- Metric Maniac
- Thank you received: 2
2007 Honda Shadow Custom
1978 Kawasaki kz650c2 cafe project
1979 Kawasaki 650sr possible bobber project
- KzJim
- Mine20
- Metric Maniac
- 750steve
KzJim wrote: MF.. thanks.. I've got that stuff covered....
Its nearly fully trial built Jim, im waiting on 2 megaphone silencers to come & then i have to weld a couple of mounting tabs for them, make some sort of carb support. I THINK i have somewhere to mount the coil supplied in your kit but for future reference on the 750 there is pretty much nowhere under the tank or around cylinder head to mount it, i could have mounted it where the horn screws on but the weather in Ireland would brobably make short work of it.
After all that its off to the powder coaters!
I'm still debating on if i should fab some sort of 'splash guard' in front of the rear wheel, i really dont want to but im afraid on the wheel throwing debris & water around the back of the engine & filters. I dont generally ride in the wet so mileage will be limited so i may be worrying about nothing.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
- Kitten Tooth
- Thank you received: 10
even the preppy chicks wanted a piece of this "Dirt kid" when i rolled up on my KZ1000
Great build. I love building stuff with my dad. 1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- KzJim
It looks like someone has been inside this engine before, the cams look as if they have very few miles on them, no wear on the lobes and the buckets show no wear either, the cam gears show no wear and the cam chain tensioner has very little wear either. Someone even went as far as to do a very basic port job, they stopped just short of the valve guides. The crank journals look great too.. I'm going to plasti-gauge them and see what the tolerances are, I suspect they will be well with in tolerance.
The transmission doesn't show any wear on the tooth faces at all... the clutch plates are at max thickness too.
Over all the inside is WAY too clean for a 30 yo engine.
However the bad part is the guy was right, it has a holed piston..
It's not as bad as i expected which is good. I had expected the worst with some head/valve/cylinder wall damage.. but that's all good.. there isnt even a carbon ridge at the top of the cylinder wall, it almost looks as if someone put the wrong plug in that hole and it popped the hole in the piston.
- david1050
David
2009 Vulcan 900 Custom
1975 Z1B 900 Mod/Resto project (91 KZ1000P forks and wheels)
1976 KZ900 Cafe bought to flip
1982 KZ750R1/GPZ750 project (95 ZX7 forks, 03 ZX636 swingarm)
- DoubleDub
- KzJim
david1050 wrote: Jim it's great to see your son getting grease under their fingernails. Are you still going with the 810 kit? I’m looking forward to seeing this project completed. looks great so far.
Ya,
He was a good student and payed attention to what he was doing... After knowing someone has been inside the engine, I need to see what the bore measurements are and see if its stock or a slight over bore.. altho he still likes the 810 route.. if I can freshen up the cylinder walls and put it back together that $ that can go other places...
- jydog
- Thank you received: 9
81 KZ1000 LTD
Griffin GA
- KzJim
