  • Page:
  • 1
  • 2
Front mud guard 24 Jan 2024 06:57 #894375
  • shifterkart26
  • shifterkart26's Avatar Topic Author
  • Thank you received: 2
Does anyone make a front fender mud guard extension for a 74 Z1? Or, is there a substitute that can be modified to fit?  Thanks in advance!
Front mud guard 25 Jan 2024 15:53 #894422
  • shifterkart26
I just got the header and drag pipe back after having the old, chipped up thermal ceramic coating removed and recoated. So I was hoping to find a 3" extension.  Photo attached
Last edit: by Wookie58.
Front mud guard 25 Jan 2024 16:42 #894423
  • sf4t7
  • sf4t7's Avatar
  • Thank you received: 262
Noticed you have the same pit stand I have,  If you break any of the roller wheels I found hockey pucks are the same thickness and diameter, just drill a hole thru the center - cheap fix.  You can guess how I know.
Scotty
1974 Z1A
1015
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
The following user(s) said Thank You: shifterkart26
Front mud guard 25 Jan 2024 23:56 #894433
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1836
Stunning bike
Front mud guard 26 Jan 2024 16:55 #894481
  • Wheelhop
  • Wheelhop's Avatar
  • Thank you received: 294
I had a 1975 Honda Elsinore cr 125 (almost 50 years ago!) and it had one on front of  front fender.  You could probably find one reproduction and use it for back of front fender?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
Front mud guard 27 Jan 2024 05:26 #894486
  • shifterkart26
Thank you! Great suggestion.
Front mud guard 28 Jan 2024 05:27 #894509
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 634
Pyramid makes fender extenders. They don't list one for Z1's, but there might be an existing item that could be adapted.
pyramidmoto.co.uk/collections/extenda-fenda
We installed on non our '09 ST1300A years ago. It fit & works fine. The ST1300 front fenders are quite abbreviated at the rear.  The extender keeps the lower front chin fairing much cleaner.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Front mud guard 28 Jan 2024 06:54 #894513
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 519
Get creative! Find a piece of quality 304 stainless steel. Shape it on an anvil, or English wheel, same rounded tip for bottom, form it in to the inside and then polish it like chrome.
Use the new 2 part tube glue  from a collision shop  for panel adhesion!
Then done! Clean, Classy and Cool.
Or, of course, just another fender, cut what you want and glue that on.
If  I had a Z1 fender here I’d whip one up.
Last edit: by z1kzonly.
Front mud guard 28 Jan 2024 14:44 #894556
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 304
Get up on eBay and search Kawasaki part number 35019-1005 and you'll arrive at a rear fender flap for a KZ1000-R2...which may work for you.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Front mud guard 29 Jan 2024 05:59 #894581
  • shifterkart26
Thank you slmjim+Z1BEBE ! I ordered a couple that may be close enough to work even if I need to modify slightly.
Last edit: by shifterkart26.
Front mud guard 29 Jan 2024 14:02 #894605
  • shifterkart26
Thank you Wookie58 . It belonged to a good friend that passed away. So I purchased it from his widow and am doing a complete restoration. I am getting close to the end.
Front mud guard 29 Jan 2024 14:19 #894606
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Keep me in the loop when it's finished, that bike with such a bitter sweet back story is classic BOTM material
  • Page:
  • 1
  • 2
