KZ900 leans too much on side stand 15 Jan 2021 19:48 #841769
  • Robb2018
  • Robb2018's Avatar Topic Author
  • 76 KZ900 73 Z1 A
  • Thank you received: 29
ckahleer wrote: I doesn't look too bad to my eye.
Are your tires stock size?
When I got my KZ305, I felt it was leaning too far. I removed the kick stand and inspected bolt and hole. All was well. I too felt there was too much slop in the pivot, but decided it is suppose to be there. The bike did have an over sized rear tire. Since then, I replaced both front and rear tires. Rear went from 130/90-16 to 120/90-16. It leans slightly less now, and engine is running about 200 rpm faster at 60 mph.
The PO had just put new tires on the bike when I bought it this past October. I never bothered to check what size they were.. just assumed they were stock. You got my curiosity up. Will check that tomorrow too.
KZ900; Z1
KZ900 leans too much on side stand 16 Jan 2021 09:19 #841798
  • Robb2018
  • 76 KZ900 73 Z1 A
Here's a couple pics of the side stand. So what do you all think?
KZ900; Z1
KZ900 leans too much on side stand 16 Jan 2021 09:34 #841799
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2650
How long is it?
KZ900 leans too much on side stand 16 Jan 2021 10:07 #841800
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1888
Pictures are distorted like looking through glasses that are to strong.
My 1978 Ltd 1000 leaned to much, but not as much as your appears to. I swapped in a Kz900 side stand to straighten it up. I’ll measure both and let see what yours measures out at.
EDIT: Added photos.
I made sure the level and the yard stick were parallel and the top of the stand was sitting against the level square. The Kz900 measured 11-5/16” and the Ltd was about 3/4” less at 10-9/16”
Last edit: by Mikaw.
KZ900 leans too much on side stand 16 Jan 2021 10:46 #841805
  • krazee1
  • krazee1's Avatar
  • Thank you received: 198
One form of test rider entertainment at the plant was doing sidestand slides on the sealed concrete floors. I remember that not working out so well a time or two when the sidestand bracket had only been tack welded to the frame!
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
KZ900 leans too much on side stand 16 Jan 2021 10:53 #841806
  • kevski
  • kevski's Avatar
  • Thank you received: 156
Looks like you need to get an 1000 a stand, I did for .my ltd.
KZ900 leans too much on side stand 16 Jan 2021 10:53 #841807
  • Mikaw
  • Mikaw's Avatar
Again hard to tell but it looks like the side stand might be getting pulled to far forward by the spring, the stop on the frame might have been ground to allow more lean. Looking at the bike from a side view, the side stand should only be about, in clock relationships 6:15 on the big hand. Yours appears to be rotated clockwise too far.
The following user(s) said Thank You: Robb2018
KZ900 leans too much on side stand 16 Jan 2021 10:55 #841808
  • Mikaw
  • Mikaw's Avatar
Or a pivot bolt that is to small could cause the same over rotation
KZ900 leans too much on side stand 16 Jan 2021 11:12 #841809
  • Robb2018
  • 76 KZ900 73 Z1 A
It appears my stand is like your stand on the left. About 10.25 to the heel. I think I'll try straightening out the bend and see what that does. After heating red hot, how hard would this be to bend? And should it be allowed to cool slowly or quenched?
KZ900; Z1
KZ900 leans too much on side stand 16 Jan 2021 11:19 #841812
  • z1kzonly
  • z1kzonly's Avatar
  • Thank you received: 520
I never looked at this one I've had for a year, until I seen your post. This one has a 1970's Detroit, Electra 225, Gangster Lean! :laugh:
KZ900 leans too much on side stand 16 Jan 2021 11:31 #841814
  • Mikaw
  • Mikaw's Avatar
I have no advice on how easy/hard it will be to straighten. But you should let it cool naturally.
KZ900 leans too much on side stand 16 Jan 2021 15:20 #841824
  • Mikaw
  • Mikaw's Avatar
Are the shocks stock length?
