Metric fastener size designation nomenclature. As fully explained in ISO 965-1, Sect. 5, metric fastener size designations always begin with capital M or MJ followed by fastener nominal diameter and thread pitch, both in units of millimeters (mm), separated by the symbol "x", as follows. M10 x 1.5-6g-S means metric fastener thread profile M, fastener nominal size (nominal major diameter) 10 mm, thread pitch 1.5 mm, external thread tolerance class 6g, and thread engagement length group S ("short").
The above is from the internet and basically says:
M = metric
first number = diameter
second number = thread pitch
Then you just need to get the right length.
You could also try Jim @ Wiseguy Bolts (he sells on ebay) 920.725.4530
I bought two sets of stainless socket head cap screws for my GPz motor and carbs from this source...very reasonable, knowledgeable and helpful.
Good Luck!
Post edited by: neilage66, at: 2007/02/14 07:58
