KZ1100A2 Tachometer Bounce 30 Mar 2017 12:45 #758152
  • GPzMOD750
  • GPzMOD750's Avatar Topic Author
  • Thank you received: 148
No one has any insight to the bouncing needle?
KZ1100A2 Tachometer Bounce 30 Mar 2017 13:00 #758155
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
Do you have the KZ1000/1100 pdf manual? It has a troubleshooting section with a series of tests & flow charts for the meters.
The following user(s) said Thank You: GPzMOD750
KZ1100A2 Tachometer Bounce 30 Mar 2017 13:05 #758156
  • Thank you received: 2829
martin_csr is correct, the manual should help identify the problem. If you do not have the manual for your model take a look starting on page 5-34 at the link below. It might help. Ed
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Last edit: by 650ed.
KZ1100A2 Tachometer Bounce 30 Mar 2017 13:15 #758159
  • daveo
  • daveo's Avatar
  • Premium Member
  • Thank you received: 636
Might be easier to just replace the tach with a used one. There are lots of used bike part dealers on ebay that you might check with to find what you are after, and for a likely unbeatable price. ;)
If not for ebay, my BOTM would look something like this :lol: :
www.kzrider.com/forum/13-bike-related/605457-cool-pic#757416
1982 KZ1100-A2
Last edit: by daveo.
KZ1100A2 Tachometer Bounce 30 Mar 2017 15:36 #758172
  • martin_csr
Before buying used (which could be defective), he should do some troubleshooting.
The manual specifically mentions needle fluctuation & what to check.
KZ1100A2 Tachometer Bounce 30 Mar 2017 15:38 #758173
  • GPzMOD750
I do have that .pdf, it's for the non-shafties. I also have the print FSM for the shafties. I looked real quick in the general troubleshooting area of these manuals and didn't think to look at the specific chapter. That will be a good start. I'll go through the TS chart and see if I can figure anything out. Can I use a standard digital multimeter to test for pulses from the coil?
Daveo, I have 1 extra US spec and UK spec tach I'm hoping I'll find one that works. I also have 2 UK spec speedos. All this courtesy of ebay. I don't think there would be anyone on this forum doing anything if it weren't for the ebay parts.
The only issue with putting the other US tach on is the damper issue. The reason this particular tach is on there is the bezel is in just a bit better shape than the other one.
UPDATE: I was just digging around in the box o' instruments and found a good damper. OH YEAH! so if I can't correct the issue with the one tach I'll put on the other and see if it works.
KZ1100A2 Tachometer Bounce 30 Mar 2017 19:08 #758182
  • daveo
  • daveo's Avatar
  • Premium Member
+1
Do UK speedo gauges read in MILES?
1982 KZ1100-A2
KZ1100A2 Tachometer Bounce 30 Mar 2017 20:25 #758186
  • GPzMOD750
daveo wrote: +1
Yes they do. Problem with the KZ1100A is that they share instruments with the ELR so they're harder to find and are more expensive.
KZ1100A2 Tachometer Bounce 30 Mar 2017 20:35 #758187
  • daveo
  • daveo's Avatar
  • Premium Member
Do they max out at 85 mph like the ones in USA?
1982 KZ1100-A2
KZ1100A2 Tachometer Bounce 31 Mar 2017 04:55 #758200
  • GPzMOD750
daveo wrote: Do they max out at 85 mph like the ones in USA?
NOPE! None of that silliness.
KZ1100A2 Tachometer Bounce 31 Mar 2017 08:00 #758221
  • SmokyOwl
  • SmokyOwl's Avatar
  • Thank you received: 11
I need one of those 160mph speedos, they're hard to come by tho.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
KZ1100A2 Tachometer Bounce 31 Mar 2017 08:12 #758222
  • GPzMOD750
SmokyOwl wrote: I need one of those 160mph speedos, they're hard to come by tho.
That they are. I bought the 2 I found on UK eBay that would ship stateside. The one pictured cost me $165 shipped. It was only the Speedo and it didn't have the silver band holding the bezel on but it sat on a dealer shelf for decades supposedly. Then I bought a complete cluster for $125 shipped for spares.
