  • Page:
  • 1
  • 2
$10 Chinese vacuum petcock review 07 Nov 2023 12:12 #891418
  • ckahleer
  • ckahleer's Avatar Topic Author
  • Away
  • Thank you received: 140
The Chinese could make acceptible stuff, if they just tried a little harder. But I guess they just don't care.
I bought this petcock for my KZ400. It actually works well, now that I have it figured out.
It is listed as a ON-RES-PRI petcock, but is actually ON-OFF-PRI
The face plate is labled wrong. The position marked "RES" Is to the left, where the selector lever can't even go, and pushed to the right the petcock is off.
By grounding off the word "RES", I now really like the function of this petcock.
Down is on (when vacuum is applied), horizontal to the left is "OFF", and up serves as both "PRI" and "RES".
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
$10 Chinese vacuum petcock review 07 Nov 2023 12:49 #891421
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Thank you received: 1892
I guess if it passes fuel and doesn't leak you can't expect much more for the price
$10 Chinese vacuum petcock review 07 Nov 2023 15:13 #891432
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 313
Check out this Chinese master cylinder. It works fine for the last 4 years. We have 2, one on each GS 1100E.
They just can't get the labeling correct.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Last edit: by Kelly E.
$10 Chinese vacuum petcock review 07 Nov 2023 16:36 #891436
  • Nerdy
  • Nerdy's Avatar
  • Thank you received: 387
What do you mean? All you need to do is keep the fluid level between the lower mark and the other lower mark.
"Hi, I'm Larry..."
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
$10 Chinese vacuum petcock review 07 Nov 2023 17:21 #891438
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1883
"Hi, I'm Larry..."
"this is my brotherDarryland this is my other brotherDarryl,"
$10 Chinese vacuum petcock review 07 Nov 2023 20:49 #891448
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2644
"Hi, I'm Larry..."
$10 Chinese vacuum petcock review 08 Nov 2023 06:06 #891459
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1630
By Kelly E:  Check out this Chinese master cylinder. It works fine for the last 4 years. We have 2, one on each GS 1100E.
For next time you might be able to find a good used Japanese master cylinder. I installed one from a late model Honda CBR500.
ps: someone here on KZR reported that their made in china mc broke, either at the lever or at the handlebar mount, I forget. I've heard of other chinese parts breaking as well.
$10 Chinese vacuum petcock review 08 Nov 2023 07:34 #891464
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
  • Thank you received: 270
Friends don't let friends buy chinese parts!
Wife's little bike... 1984 GPZ 550 Kerker and DynaJet stage I kit
Wife's BIG bike...... 1981 GPZ 1100 Kerker and factory FI Mikuni RS34s W/ K&N pods
$10 Chinese vacuum petcock review 08 Nov 2023 07:39 #891465
  • scubaanders
  • scubaanders's Avatar
  • Thank you received: 233
I must admit that I bought a petcock made of chineseium this spring for my Gpz900, as i failed to restore any of my old oem taps to a good working condition. I bought one that was 30USD from the ebay seller "ursuper".
it both looks and works like the oem, even though I keep a close eye on it, I certainly prefer a vacuum tap to a fully manual, considering how fast modern fuel gungk up the carbs.
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
$10 Chinese vacuum petcock review 08 Nov 2023 08:13 #891468
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Like so many things quality can't be judged purely on origin of manufacture, let's not forget "Dyna" ignitions are made in China (and the components of many more things not advertised as "of Chinese origin") I suspect the copy Dyna-S ignitions all over Ebay for a third of the price of the originals are probably coming out of the same factory without the "blue sticker"
I don't dispute a lot of the really cheap stuff is garbage but I have bought some things without issue. Some of the "odd size" taps and dies that I will use once in my project and probably never again (m20x1.5 for the hub on my speed sensor conversion) don't warrant the price for "quality" alternatives £12 vs £60
Last edit: by Wookie58.
$10 Chinese vacuum petcock review 08 Nov 2023 08:53 #891469
  • ckahleer
  • Away
If it weren't for Harbor Freight and other Chinese tool suppliers, I would have little more than basic hand tools. But now with tools at 1/4 the price, I have a collection that can take on most projects. These cheap tools give the DIY guys the ability to get it done.
On the other hand, when I have a job that needs to be turned over to the professionals, and I see they use Harbor Freight tools, I turn and run.
94 KE100
81 CM200t
82 KZ305
85 VT 500c
85 VF1100c
Last edit: by ckahleer.
$10 Chinese vacuum petcock review 08 Nov 2023 10:15 #891471
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
Agreed, the tools I earned my living with are all Snap-On but for occasional use it doesn't justify the price (most of the time)
  • Page:
  • 1
  • 2
