  • Page:
  • 1
1980 LTD 1000 Jetting 17 Jan 2021 13:45 #841893
  • CopterDr
  • CopterDr's Avatar Topic Author
  • Thank you received: 0
Asking what you guys think would be a starting point for jetting a stock 1980 LTD 100 equipped with a Kerker 4in1 exhaust. Just purchased the bike along with a new Kerker.
1980 LTD 1000 Jetting 17 Jan 2021 15:45 #841904
  • Mikaw
  • Mikaw's Avatar
  • Thank you received: 1854
If it has stock air box no jetting should be necessary. Why do you want to re-jet? Is the bike not running well? You Have to do all maintenance adjustments first before you can think about tuning. Valve lash, timing, compression test. Maybe the carbs just need a good cleaning. Check that you have a fully charged and in good condition battery. Aslo need to know you have 12.6 volt at the primary of the coils... lots to check before you try to tune.
1980 LTD 1000 Jetting 17 Jan 2021 15:47 #841905
  • Mikaw
  • Mikaw's Avatar
This manual should be close enough to get you in the ball park
kzrider.com/modules/ServiceManuals/Kawas...Service%20Manual.pdf
1980 LTD 1000 Jetting 17 Jan 2021 16:10 #841906
  • hardrockminer
  • hardrockminer's Avatar
  • Away
  • Thank you received: 1022
I have an '80 LTD. Right now it has a Z1 airbox and a 4/1 exhaust. I have a set of '76 carbs on it with stock jetting. It runs just fine.
1980 LTD 1000 Jetting 18 Jan 2021 07:11 #841919
  • CopterDr
Thanks for the input. it helps alot.
  • Page:
  • 1
