Drag strip trip. 06 Jul 2017 05:00 #766205
  • KZB2 650
  • KZB2 650's Avatar
  • Thank you received: 265
I remember talking to that young lady that ran her 650 at Byron drag strip for years (can't think of her name but have it somewhere) and she had a 10.91 time on her plate (et racing at the time) .... it was upper 80s and humid and she said come back when its in the 60s and she'll have 10.70s on it. Maybe you need to move up north......:silly:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: by KZB2 650.
Drag strip trip. 06 Jul 2017 20:07 #766282
  • zukdave
  • zukdave's Avatar Topic Author
  • Thank you received: 229
KZB2 650 wrote: Maybe you need to move up north......:silly:
Nope game plan is go back to east Tenn.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Drag strip trip. 07 Jul 2017 11:26 #766314
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
  • Thank you received: 107
Jesus - home spun old 2 valve 650's running into the tens...deep respect for the builders, and new perspective gained for me!!!
I'm going to have to break into the 10's with Beater II now! No more excuses!
Just a question though - what do you guys / gals weigh in at? If you are under 130lbs, I can see how you are shredding my times...
-Scott
Drag strip trip. 08 Jul 2017 12:56 #766425
  • zukdave
Scott full learthers and gear I'm about 200 lbs. Me and the bike around 630 lbs.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 08 Jul 2017 13:07 #766426
  • Kray-Z
  • Kray-Z's Avatar
Yep, me too, so the bar is raised ever higher...damn fast guys on these little engine bikes! How do you do that?!
Guess I shouldn't tell you I got eliminated heads up (same 12.00 dial in) by a Shelby Mustang GT500 two years ago while racing my (albeit tired and nearly stock) GPz1100, then?
-Scott
Drag strip trip. 08 Jul 2017 13:22 #766429
  • Kray-Z
  • Kray-Z's Avatar
BTW - I was stunned by how fast the kids running Junior Dragster were going. 7's in the 1/8th. And the hardware! These are not lawnmower engines! Most were 100% billet aluminum hand built versions of the Koehler and Briggs. They "crackle" like top fuelers! HOLY-S!
-Scott
Drag strip trip. 08 Jul 2017 18:11 #766442
  • zukdave
Our track hosts the Southwest jr dragster championship race.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: by zukdave.
Drag strip trip. 09 Jul 2017 07:29 #766469
  • KZB2 650
  • KZB2 650's Avatar
Young lady am guessing was 170 in leathers, helmet etc...... plus a slick, wheelie bar... .400 lift cam and I'm 98% sure 12.5 to 1. Read she ran 10.4s after fitting custom 871cc Arias pistons I think it was but didn't see it or get to talk to her about it.
1978 KZ650 b-2
Drag strip trip. 11 Jul 2017 06:17 #766660
  • TheTrout
  • TheTrout's Avatar
  • Thank you received: 56
I hope to be heading back to the strip on the 21st. My stock KZ1000 ran 12.20's just a few years ago. I went up a little to a 1075 Wiseco piston, race cut trans, no other changes. I am hoping to break into the high 11's. Can hardly believe 10's on a 650 motor, that's damn fast! Here's a video from many years ago:
1978 KZ1000B2
Drag strip trip. 11 Jul 2017 17:55 #766722
  • Stateline Kev
  • Stateline Kev's Avatar
  • Thank you received: 0
How long did you add to your rear arm? Looks great
Drag strip trip. 11 Jul 2017 20:12 #766733
  • zukdave
My arm is a 83 GPz750 I added 5 1/2" for a total of 8" over stock.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Drag strip trip. 21 Aug 2017 16:34 #769392
  • zukdave
Haven't been to the track in a while but have got in some street mile's on the bike.
Been so hot here I've been going for early morning ride's when it's cool I can add some timing and turn the power up
but if I do a close bike night it's a 100 degrees and it don't like that much timing.
So since I can plug in the laptop and preload four timing curve's I loaded an AM and a PM curve.
I set the PM curve to start pulling timing out at 7000 rpm's and pull one degree every 1000 rpm till red line.
It kill's the power some but it let's me ride it in this heat on 93 pump gas.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
