  • Page:
  • 1
  • 2
Time-sert vs Helicoil? 24 Dec 2017 07:53 #776578
  • zed1015
  • zed1015's Avatar
  • Thank you received: 1490
Remains of the bolt should easily drill out with a sharp HSS drill bit and some cutting fluid.
The core should be relatively soft but if not use a cobalt bit.
Carefully centre punch and start with a 3mm - 1/8th inch bit.
Once you got that in go 4mm the finish with 5mm.
If you are dead centre the thread coil will be left and should either pick out or easily clear with an M6 tap.
Stock bolt is never as long as the threaded hole so if you do catch the thread towards one side a longer bolt will still tighten.
The following user(s) said Thank You: slmjim+Z1BEBE
Time-sert vs Helicoil? 24 Dec 2017 09:00 #776580
  • les holt
  • les holt's Avatar
  • Vendor
  • Thank you received: 288
I personally have had good luck with the helicoils and not with the key locking inserts. Not enough experience with the timeserts to judge so I did a little digging to see what I could find that was fact based. Found this youtube video that had merit to it's testing.
Les Holt
PDM Custom Fabrications
The following user(s) said Thank You: slmjim+Z1BEBE, wera90ex
Time-sert vs Helicoil? 24 Dec 2017 11:19 #776583
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar Topic Author
  • Thank you received: 665
Hi les holt,
That's very good empirical data. Thanks for finding & posting that!
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
Time-sert vs Helicoil? 26 Dec 2017 07:17 #776624
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
Ok... just my 2 worthless cents on this subject matter.....
Regardless of the manner you go, PREP is everything.
For us DYI, heli coils are easier to prep/install henceforth easier not to F-Up..... As others mentioned,, certs require more medal to be removed and will require ideal insertion depth accuracy for ideal installations, cover fits, leak prevention etc...
Now key logic for CAM cap / valve cover bolts, engine case/cover bolts etc... How much torque on the bolt are you requiring... that's right very little - SNUG fit only.
Conclusion, save your self a huge headache and go with Heli coils for most applications you'll be just fine.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Time-sert vs Helicoil? 26 Dec 2017 12:52 #776629
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1929
+1
For a good centered bore i use special center punches (a broken cam cap bolt).
Static or adjustable center punches dependent of the bore diameter.
and than a counter clockwise drill bit, mostly the broken part of the threat came out easily during this process!!!
Michael
The following user(s) said Thank You: jeffz
Last edit: by Scirocco.
  • Page:
  • 1
  • 2
