1981/82 KZ440 Valve adjusting caps 08 Aug 2020 08:48 #832411
  • bluejacobs
  • bluejacobs's Avatar Topic Author
  • Thank you received: 2
Hey all, been a while since I’ve been on here and hoping it’s still the wealth of information it used to be. Short story is I recently got a 1981 kz440 A and an 82 kz440 D nad am diggin into them. The 81 has sat for 10 years and is a long term project. The 82 is a bike I’m tuning up for my friends first set of wheels! It runs drives but needs some TLC, one thing being valve clearance checks.
Anyone know what size those hex caps are so I don’t have to buy a whole socket set?
Anyone have a torque spec for them? Neither are listed in the service manual I found.
Cheers!
1981 Kawasaki KZ750 LTD - back on the road after 4 years storage
1981 KZ440 A - project, 80% done
1981 KZ440A - donor bike
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 09:58 #832413
  • TheFlyingFreemole
  • TheFlyingFreemole's Avatar
  • Thank you received: 8
Mine (‘77 1000ltd) are 10mm hex heads. Same for the cam cover as the cam caps.
Can’t recall exact torque for them off the top of my head but there is a bit of information about the torque values in my 77 LTD Build page
1977 KZ1000 LTD B1 (needs minor fine tuning)
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 10:03 #832414
  • bluejacobs
Hey thanks for the reply but to clarify I’m not talking about the valve cover bolts, I’m talking about the 4 large valve adjustment access caps ... figuring they must be 30mm or larger? Any idea ?
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 10:17 #832415
  • TheFlyingFreemole
This may get you closer
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 10:25 #832416
  • bluejacobs
No that’s still not what I’m talking about. The 440 has 4 big plugs with large hex heads that allow you to access and adjust the valves without removing the entire cover.
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 12:42 #832419
  • loudhvx
  • loudhvx's Avatar
  • Thank you received: 1615
Sorry, I don't have a measurement for that.
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 13:35 #832423
  • hardrockminer
  • hardrockminer's Avatar
  • Thank you received: 1021
Measure across the flats and buy that size wrench or socket.
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 14:58 #832432
  • bluejacobs
Yep that’d be them just wondered if someone had the size offhand since these bikes are not stored where I live and not plainly accessible
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 14:59 #832433
  • bluejacobs
hardrockminer wrote: Measure across the flats and buy that size wrench or socket.
Jeez I’d never have thought of that - bikes aren’t stored where I live and wondered if anyone had the size offhand so I can order the correct socket instead of guessing
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 15:21 #832437
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
  • Thank you received: 366
I understand the desire for a correct size socket or wrench, but IMO this is what adjustable wrenches are made for.
1977 KZ650 B1
Pods and Denco header
This is my Z
OLD KAW OWNERS SMILE ALOT
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 15:23 #832438
  • bluejacobs
gd4now wrote: I understand the desire for a correct size socket or wrench, but IMO this is what adjustable wrenches are made for.
So I threw a crescent wrench on her and she didn’t want to budge even with healthy dosing of penetrating oil. Really don’t want to round these off, and in my experience impact is the best option at this point with PB Blaster
1981/82 KZ440 Valve adjusting caps 08 Aug 2020 15:27 #832439
  • loudhvx
  • loudhvx's Avatar
There is usually an oring in there so using heat is probably out of the question. I would probably try tapping on it using a piece of wood to prevent marring. I would tap in a circular pattern around the outer surface of the plug... clockwise and counter clockwise. The idea is to shock the corrosion into releasing.
