Scirocco wrote: A big soldering iron and tin is the ultimate weapon to close pinholes.
That is exactly what I used... though nothing that fancy.
Several days after getting a tank professionally painted, it developed several pinhole leaks. I was not very happy to say the least.
But having done quite a bit of soldering ever since I was a kid, I felt I could give it a shot.
I found a 1/2" rod of bronze and stuck a wooden handle on it and cut it at about a 45 degree angle to give it a tip, and ground it smooth.
I heated it red hot and stuck it into a small puddle of gasoline to see if it would ignite. It did not.
Next I used a small piece of sandpaper to sand the paint down to the metal in a tiny spot centered on the pinhole leak.
I filled the tank most of the way with water and situated the tank so a bubble of air would form where the pinhole was.
Then I used some plumbing acid flux on the small spot keeping it off the paint.
I heated the rod and tinned it with lead-free solder.
Then I heated the rod again and placed the tip right on the bare spot and fed in some solder. The solder naturally flowed then formed a smooth little patch over the bare metal right up to the paint. The paint did not get burned that I could see. I think the temp was just right to melt the solder, and the water in the tank prevented the metal from getting hot enough to burn the paint.
There was one area that had extensive pinholes, but luckily that area is covered up by the seat. Only one little pimple of solder is visible on the tank normally. Most people don't seem to notice it. It's shiny and I guess even though it's a different color, it blends in. I've never had anyone ask why there was a solder bump on the tank.
I didn't have too much hope for this repair, but it could not have gone any better. 6 years later the repairs seem to be holding just fine.
I really need to get better photos of it. I wish I had made a video at the time, but I was expecting the worst.
