Difference 76 KZ900/78 KZ1000 Rear Sprockets??
  • gershom
  • gershom's Avatar Topic Author
04 May 2009 11:16
#287822
Hello,
Wondering if anyone knows if a rear sprocket from a 1976 KZ900B (LTD w/Mag wheel) will fit on a 1978 KZ1000A (laced rim) without any issues? All the aftermarket suppliers show different part numbers.
Thanks,
Tim
1978 KZ1000A2A, 1971 CB500K, 1972 CB350F, 1974 Guzzi 850T, 1974 Guzzi 850T, 1975 Guzzi 850T Hot Rod, 1966 BSA A65 Lightning, 1978 SR500
  • timebomb33
  • timebomb33's Avatar
Re: Difference 76 KZ900/78 KZ1000 Rear Sprockets??
04 May 2009 11:44
#287823
the ltd used the same bolt pattern and hub size as the earlier z1's and the kz's used a different sized hub and bolt pattern i'm guessing because of the size difference in motor output i'm thinking the factory was being parinoid.
I THINK MY POWERBAND BROKE
  • gershom
04 May 2009 11:51
#287825
Cool. Appreciate the info! I was going to take a new sprocket that I had bought for a 76 KZ900LTD and use it on the 78 1000. Guess I will just buy a new one for the KZ!!
  • gershom
05 May 2009 08:01
#288109
I was thinking about this last night. On the standard KZ900 with laced rims, there may be a difference. On the 1976 KZ900B (LTD) model, there shouldn't be a difference. I wouldn't think they used a different rear mag rim in 1976 and 1977. They should all be the same.
Anyone else have input on this??
  • RonKZ650
  • RonKZ650's Avatar
05 May 2009 09:44
#288137
The 76 900LTD was the first factory cast wheel from Kawasaki and yes it was unique to that year. In 1977 with the KZ1000LTD they had the more familier wheels used from there on out.
05 May 2009 10:52
#288155
Yes. The KZ900-B1 LTD came factory equipped with genuine Morris Mags. Later KZ models were no longer fitted with Morris Mags, but were fitted with similar appearing mags from Kawasaki. When directly compared side by side, the difference between the two mag designs is readily apparent.
Good Luck! :)
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
05 May 2009 14:04
#288188
The KZ900 LTD rear sprocket is UNIQUE to that bike. It will NOT fit on any of the KZ1000 sprocket carriers.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • 76 LTD
  • 76 LTD's Avatar
10 May 2009 16:36
#289957
The 76 900 LTD sprocket is a one off it wont fit anything else and nothing else will fit it.just like the rear brake Master cylinder and a few other parts.
