Long-
I think that I did to many things at once and now I don't know which mod is causing which problems.
I feel somewhat overwhelmed at the moment and I don't even know what to do next. Maybe someone here has some ideas.
The Bike is an 1981 KZ650H1
Here is a gallary pic
I replaced the carbs with my '81 KZ1000 BS34's (see this
Thread
from last September)
I installed #140 main jets and #40 pilot jets and added K&N filters and a MAC 4x1 header. The bike would start but it would go stright to 6600RPM and stay there. I read in several posts here that this is a sign of leaking manifolds so I used my handheld gas torch to check for leaks. I did not get any drops in RPMs what so ever so I tried WD40 and got the same results. So I may be wrong but I don't think that there is a leak.
I discovered that the idle screws were not set remotely close to what the (KZ1000) manual said that they should be which is 1 1/4 turns out from a light seat.
when I set those things got a little better. The RPMs dropped some which allowed me to let the bike run long enough to discover that it was only firing on 1 & 4.
Since this seems like a coil or electrical problem let me side step here and list the electrical mods.
3 ohm green Dyna coils, Dyna wires, Dyna S ignition, NGK B8ES Spark Plugs and the coil mod that many are now doing.
I check for spark on all of the plugs and the spark is big and blue and you can hear it snap. In fact once I had the loose plug wire in my hand while it was running and the spark actually jumped over to the engine several inches.
So since it has spark on all 4 I started looking at float levels as the cause for some cyl's not firing and discovered that in 3 of the 4 carbs the fuel levels in the tube were above the gasket by about 3=5mil. and 1 was a little low but not bad. I set the float levels a total of 3 times and each time I put the carbs back on the bike a different cyl would be out. I have the levels close now and it is down to #3 not firing and idle is still up around 3500.
Here are the rest of the problems:
On the cyl's that are firing the pipes are so hot that they smoke. (black MAC pipes) I know that they get pretty toasty but this seems like they are much hotter than normal.
Grey smoke out the back of the pipe.
Some backfiring although it is less now.
Plugs are black (rich right?)
Here is the kicker: When I turn off the bike using the off switch the bike dies as it should but then a few seconds later when I turn the key off, the bike backfires real good and sounds like the whole thing is gonna blow.
I am starting to worry that summer 07 is going to come and go with out me riding at all. Any ideas on how I can dial this setup in some and get it stable?
Michael:kiss:
