Tip For Removing Broken Drill Bits Or Easy Outs 04 Mar 2016 11:58 #713806
  • kzharpe
  • kzharpe's Avatar Topic Author
  • Thank you received: 3
Long story short, I broke off one of the carb holder bolts on my 77 kz650. I was a machinist for several years so I thought this would be an easy enough fix......it wasnt. I tried multiple easy outs, but like most people with this issue on the forum...it failed horribly. My next step was just to drill the darn thing out and retap the hole. Im fairly confident in my ability to drill a straight hole so I went for it. Needless to say the smaller drill bit I was using to drill a pilot hole broke. At this point I was ready to take off the head and take it to the machine shop. However before that I wanted to try and drill that bit out using a solid carbide bit. Wouldnt you know it, my budy has my carbide bits (he lives 200 miles away). I head for lowes looking for anything that is carbide. I ended up coming home with a rotozip bit that was carbide. I threw it in the drill and fired away. As soon as I got started I heard a snap. The snap was the smaller bit shattering into pieces. A little wd40, a few blasts from the air hose, and a couple more passes with the rotozip bit and I was home free. Pulled out my titanium bits and an m6 tap now we are good to go. Just wanted to share this because it may save someone a trip to the machine shop in the future. Ill post a link to the bit that I used as well. Oh and by the way your going to want extremely high rpm's so I would either use an actul rotozip if you have it or use an adapter for a dremel
www.lowes.com/pd_123166-353-XB-TC1___?pr...&Ntt=rotozip+bits#3d
1977 KZ650
The following user(s) said Thank You: Mcdroid, pete greek1
Tip For Removing Broken Drill Bits Or Easy Outs 04 Mar 2016 13:43 #713824
  • car5car
  • car5car's Avatar
  • Banned
  • Thank you received: 20
Thanks! I didn't know about carbide bits
96 Yamaha Royal Star
82 Yamaha Virago 920
Tip For Removing Broken Drill Bits Or Easy Outs 04 Mar 2016 13:49 #713825
  • kzharpe
They work wonders but solid carbide bits are between $40 and $60 a piece, that's why I'm glad this rotozip bit worked. Definitely going to have my buddy ship mine back asap
1977 KZ650
Tip For Removing Broken Drill Bits Or Easy Outs 04 Mar 2016 14:11 #713829
  • Thank you received: 2829
Thanks for the tip, but it's MUCH easier to use Kroil to break the bond between the screws and engine than it is to deal with broken fasteners. The carb holder screws on mine had not been touched since the bike was new, and after about 30 years did not want to budge. I soaked them for 3 days with Kroil and used a JIS screwdriver bit, and they came out without a problem. That stuff really works, and I would not work on my bike without it. Ed
Attachment Kroil-2-3-4.jpg not found
Tip For Removing Broken Drill Bits Or Easy Outs 04 Mar 2016 14:18 #713831
  • kzharpe
Yeah I actually just ordered some per your advice. I used pb blaster but it clearly didn't work. Worst part is that it was the very last one I took off the bike. All the others came off no problem
1977 KZ650
Tip For Removing Broken Drill Bits Or Easy Outs 06 Mar 2016 05:46 #714078
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
Recently I had to remove a snapped screw that held the tank badge on , first I used oil and a tiny bit to center drill a hole , I have been down that road with easy outs and didn't want to try it again. :whistle:
I was going to try to beat a small flat blade in there to spin it out.
Like you all I have is PB blaster on hand and I know that the instructions tell you to tap the part and respray so I decided to try using my engraving tool to vibrate it first.
When I touched the tip to the busted screw it shattered the screw and I was able to fish all the pieces out with a dental tool B)
That's good to know about carbide Dremal bits ;)
78 KZ1000 A2A
The following user(s) said Thank You: Patton
Last edit: by bluej58.
Tip For Removing Broken Drill Bits Or Easy Outs 05 Aug 2016 17:11 #737586
  • Tune-A-Fish
  • Tune-A-Fish's Avatar
  • Thank you received: 1
If any of the broke off part is sticking up, weld a nut to it and turn it out.
I didn't come here and I ain't leavin
Tip For Removing Broken Drill Bits Or Easy Outs 05 Aug 2016 20:47 #737606
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Tune-A-Fish wrote: If any of the broke off part is sticking up, weld a nut to it and turn it out.
LOL. Not on my gas tank ...
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Tip For Removing Broken Drill Bits Or Easy Outs 05 Aug 2016 21:15 #737608
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2621
B)
Tip For Removing Broken Drill Bits Or Easy Outs 07 Aug 2016 10:16 #737711
  • markitzero
  • markitzero's Avatar
  • Thank you received: 0
I've used a concrete drill bit to break out broken drill bits in similar scenarios with success.
Tip For Removing Broken Drill Bits Or Easy Outs 07 Aug 2016 14:25 #737734
  • SWest
  • SWest's Avatar
  • 10 22 2014
I've tapped on them to loosen them enough to pull out with a magnet. PITA but it can be done.
Tip For Removing Broken Drill Bits Or Easy Outs 08 Aug 2016 13:20 #737867
  • westmiltonfab
  • westmiltonfab's Avatar
  • Thank you received: 23
That works really well, but it also works better when after you weld it walk away and let it cool down before you extract it. Heat makes everything swell so let it cool down.
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
