  • Page:
  • 1
  • 2
True Coil Tester 04 Dec 2012 17:59 #561376
  • loudhvx
  • loudhvx's Avatar Topic Author
  • Thank you received: 1615
It's hard to confirm a coil is good unless you actually stress it. Even better would be if works after a thorough hosing down with water.
The following user(s) said Thank You: TwoCam
Last edit: by loudhvx.
True Coil Tester 04 Dec 2012 18:06 #561377
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
  • Thank you received: 245
Works.
Sick!
Details and/or cost?
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
True Coil Tester 04 Dec 2012 18:07 #561378
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
  • Visitor
Nice item....your to smart for me..... :unsure:
Stick your finger in there..... :woohoo: :woohoo:
Last edit: by 4TheKZ1000.
True Coil Tester 04 Dec 2012 19:21 #561385
  • loudhvx
There's not too much to add for details, other than:
The gap to jump should not exceed 1/2" for older coils and bikes.
Coils meant to run on higher compression motors 10:1 or greater, should be able to safely go about 3/4".
The coil being tested there is a 1977 KZ650 coil. I was putting it under more stress than it should have on it (it's a throw-away coil, but obviously still works pretty good, at least while dry).
The HEI module is the original 4-pin type. It should be on a heatsink plate, but the one I have there is probably overkill. It should only get slightly warm over 20 minutes or so.
Any standard motorcycle or scooter battery should provide more than enough power to run it for a long time.
The schematic is for a design requiring the coils are 2 ohm or higher resistance. A lower resistance coil should use a ballast resistor in series to make up the difference.
That particular unit is going to my buddy who does a lot of work on bikes.
Getting shocked is all part of the process on a project like that :)
True Coil Tester 04 Dec 2012 20:49 #561402
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
That's pretty cool Lou.
Thanks for sharing.
JD
78 KZ1000 A2A
Last edit: by bluej58.
True Coil Tester 04 Dec 2012 23:40 #561419
  • steell
  • steell's Avatar
  • Thank you received: 206
Just imagine, thread a piece of safety wire thru the seat cover on the drivers seat, stash your little box under the seat and wire it to ignition, set controls so it comes on with ignition.
Hide around corner and watch when owner gets in car and turns on ignition.
Run away, very rapidly!! :evil:
Got chased clear out the main gate at RAF Mildenhall by my very irate boss. The laughing gave me away, but it was so funny when his head hit the roof and he bit his cigar in two.
Still haven't figured out what I want to be when I grow up.
Gonna have to give this one some thought :evil:
Last edit: by steell.
True Coil Tester 05 Dec 2012 02:07 #561437
  • loudhvx
:woohoo: :laugh:
True Coil Tester 06 Dec 2012 00:16 #561579
  • LarryC
  • LarryC's Avatar
  • Thank you received: 309
bluej58 wrote: That's pretty cool Lou.
Thanks for sharing.
JD
x2 :)
Larry C.
True Coil Tester 06 Dec 2012 07:22 #561630
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
Awesome Lou..... B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
True Coil Tester 06 Dec 2012 07:49 #561631
  • lushbaugh
  • lushbaugh's Avatar
  • everybodys a pro......
  • Thank you received: 35
this is awesome, i need one of these.
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
True Coil Tester 14 Apr 2013 06:22 #582247
  • loudhvx
Here's a video of two RD400 coils I tested for a friend. Whenever he tested for spark, he had it on both coils. But the bike would always sputter on one cylinder, then foul that plug.
It shows how a coil can seem to be ok at first, but can gradually go bad.
After closer inspection, we found the coil may have a possible leak at the wire attachment. We cleaned it up and replaced the wire. Hopefully it will work long enough to confirm the carbs are ok.
EDIT/update: After replacing the wire at the coil, it has been running great on both cyclinders.
The following user(s) said Thank You: kzgeoff, TOOLS1
True Coil Tester 31 Mar 2016 18:36 #718581
  • loudhvx
I've been working on a new design for a tester since the HEI modules are now made differently. Also, this should prove to be cheaper since the driver costs about $5 instead of $20.
But while working on it, I realized I could make a controller to do this:
  • Page:
  • 1
  • 2
