BR wrote: ... then immediately as oil light appears wants to die. ... My bike died while riding immediately after oil light came on. ...
This is slmjim,
Not familiar with the 750's but, maybe OP and us (the forum) need to look at what's happening and not what we're seeing. To wit:
An electrical circuit (oil pressure indicator) energizes (malfunctions) without apparent reason and, at the same time, a different electrical circuit (ignition) malfunctions.
Consider the possibility that the oil pressure indicator being energized might be a red herring, and that an electrical short, open or poor ground could be responsible for both symptoms.
Undoubtedly, correct oil pressure should be confirmed for obvious reasons. It just seems suspicious that two separate electrical systems would malfunction simultaneously.
Not being familiar with the 750's I can't really offer advice past what I've written and, admittedly, I may be off base completely. My early career as a Tech in complex electro-mechanical devices (photocopiers, printers, MFP's etc.) led to learning the concept of "look at what is happening, not what one is seeing".
That's all I or The Lovely Z1BEBE have to offer at the moment.
Good Ridin'
slmjim & Z1BEBE
