  • Page:
  • 1
  • 2
Pops out of gear in second! 30 Oct 2009 12:15 #330506
  • rkan
  • rkan's Avatar Topic Author
  • Thank you received: 0
Every once in a while, while I'm really letting it rip in second gear, it pops out of gear. I can shift back into it again right away but it is a little unnerving. Is it a sign of clutch wear? I ride a '78 650b
1978 KZ650B
Pops out of gear in second! 30 Oct 2009 12:36 #330508
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 305
Uh, probably not a clutch problem...it is possible that is a bent shift fork. :(
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Pops out of gear in second! 30 Oct 2009 13:13 #330513
  • nads.com
  • nads.com's Avatar
  • Thank you received: 20
Sounds like second gear might need to be back cut or replaced. These are known for this, mine did it so bad shifting from 1st to sec on a wheelie, it would jerk back and forth rapidly. I back cut my own but wouldn't reccommend it. Always check the forks while it's apart. I couldn't use second gear on mine it got so bad.
Last edit: by nads.com.
Pops out of gear in second! 30 Oct 2009 15:21 #330534
  • kawsakiman
  • kawsakiman's Avatar
  • Thank you received: 6
Congratulations!
Your about to get very well acquainted with your bike.
You need to split the cases to change either second gear or the whole transmission.
Second gear is the weak link in almost every make of motorcycle.
Pops out of gear in second! 30 Oct 2009 15:57 #330538
  • bluej58
  • bluej58's Avatar
  • Thank you received: 511
I had that problem before with my 78 KZ1000 and had to split the cases.
When I did I found that the circlip had came off the shift rod because the groove was not cut deep enough.
An easy fix once I got to it.
Same symptoms, the bike would would still shift, but it would pop out when I was getting on it.
If this is the problem you will see it right away and it is just a matter of cutting a deeper groove and using a fresh circlip.
I am lucky to know a good machinist.
You don't have to pull out the gear cluster or anything real tricky.
And if somebody says you should dress up the first gear while you have it that far apart and he'll do it for cheap
"Don't do it", but thats a story for some other time.
Good luck JD
78 KZ1000 A2A
Pops out of gear in second! 30 Oct 2009 16:38 #330552
  • timebomb33
  • timebomb33's Avatar
  • Thank you received: 10
normally if a transmission is popping out of gear it means the shift dogs on that gear are worn out it most likley means second gear on both shafts will have to be replaced or at the very least if they aren't to badly chewed up undercut
I THINK MY POWERBAND BROKE
Pops out of gear in second! 30 Oct 2009 17:39 #330555
  • bluej58
  • bluej58's Avatar
Hey rkan,
How many miles you got on that thing ?
78 KZ1000 A2A
Pops out of gear in second! 09 Nov 2009 18:46 #332492
  • rkan
It's got about 24k miles. Today it did it again right as i was about to shift at 8 grand and the motor wound up to maybe 11k rpm. My buddy behind me said that black smoke came out the exhaust right then.
1978 KZ650B
Pops out of gear in second! 10 Nov 2009 06:35 #332600
  • Old Man Rock
  • Old Man Rock's Avatar
  • Thank you received: 225
"i was about to shift at 8 grand"...
Am I understanding this correctly where your running in 1st gear up to 8Krpm to shift into second! :blink:
:pinch: :whistle:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Pops out of gear in second! 10 Nov 2009 14:11 #332671
  • racer54
  • racer54's Avatar
  • Thank you received: 114
All the time! That's the fun part!:laugh:
Pops out of gear in second! 10 Nov 2009 14:13 #332672
  • rkan
Haha well I was in 2nd gear about to shift into 3rd and it was on an on ramp.
1978 KZ650B
Pops out of gear in second! 10 Nov 2009 16:35 #332688
  • PLUMMEN
  • PLUMMEN's Avatar
  • Thank you received: 103
shift faster! :laugh:
  • Page:
  • 1
  • 2
