Z2 750 crank (Bossie the Kaw) 21 Mar 2018 15:27 #780579
  • missionkz
  • missionkz's Avatar
  • Thank you received: 184
Steve,
I'm curious if you've replaced the front wheel bearings in a while and is the pseudo axle shaft you are using for this jig, the exact same diameter as a real axle shaft?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Z2 750 crank (Bossie the Kaw) 21 Mar 2018 15:56 #780581
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
  • Thank you received: 2611
Bearings are recent. The shaft isn't the same size as the axle. The bearings spin freely.
Z2 750 crank (Bossie the Kaw) 21 Mar 2018 19:39 #780597
  • missionkz
Ok. I would think that if the shaft is a bit too much smaller, the geometry would be that the mass would be slightly below the center of rotation and make it a bit harder to balance using gravity.
Bruce
1977 KZ1000A1
Z2 750 crank (Bossie the Kaw) 22 Mar 2018 07:18 #780614
  • SWest
  • 10 22 2014
As long as the bearing spins freely I doubt that would be an issue. When I change the tire I'll try it with the axle first to check my work. So far no hop.
Z2 750 crank (Bossie the Kaw) 22 Mar 2018 09:32 #780618
  • missionkz
Yeah maybe right. If the inner race is not moving, then the wheel is rotated around it any how.
Bruce
1977 KZ1000A1
Z2 750 crank (Bossie the Kaw) 22 Mar 2018 20:32 #780667
  • SWest
  • 10 22 2014
Still have a slight squeak.
Z2 750 crank (Bossie the Kaw) 27 Mar 2018 14:10 #780905
  • SWest
  • 10 22 2014
I guess I'll have to use the smaller tire.
Last edit: by SWest.
Z2 750 crank (Bossie the Kaw) 28 Mar 2018 18:48 #780950
  • SWest
  • 10 22 2014
Found the squeak.
Z2 750 crank (Bossie the Kaw) 31 Mar 2018 06:43 #781063
  • SWest
  • 10 22 2014
So far so good. B)
Z2 750 crank (Bossie the Kaw) 03 Apr 2018 16:38 #781243
  • SWest
  • 10 22 2014
Jeff (Z1E) got me rethinking about how I was going about things. Most I already do but when it comes to carb sync, I'll have to try it his way. Thanks Jeff.
Z2 750 crank (Bossie the Kaw) 04 Apr 2018 07:40 #781264
  • SWest
  • 10 22 2014
Plugs are looking better.
Z2 750 crank (Bossie the Kaw) 07 Apr 2018 08:01 #781392
  • SWest
  • 10 22 2014
Routine maintenance.
Not so routine
