Wideband O2 kit recommendations?
  • Zaddict
  • Topic Author
  • Enjoying my Zaddiction!
10 May 2024 17:34 #898866 by Zaddict
Wideband O2 kit recommendations? was created by Zaddict
Hi All,
I'm thinking I'd like to install a wideband O2 sensor to help dial in my carb settings for my new Wiseco 615cc setup.  I see a lot of slick looking systems out there but it doesn't seem like many (any?) are designed for motorcycles. I'm thinking the gauge would need to be waterproof, and I haven't found any that include mounting hardware. I'm looking for recommendations and/or experiences people have had. Thank you!
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
10 May 2024 19:07 - 11 May 2024 10:25 #898870 by Injected
Replied by Injected on topic Wideband O2 kit recommendations?
I think if you were doing any carb testing your not going to go out in a rain storm, you may get caught in one but with the precise forecast these days that is quite unlikely.
On the 8th page of my project build I made a gauge cover and mount for a AEM AFR UEGO gauge (self contained gauge and controller)
In the past I have used a Innovate controller kit thru a PC (tuning a alcohol injected drag bike)
I also am doing a DFI conversion using a 14 point seven brand controller with a Mirosquirt ECU. Both setups use Bosch LSU49 O2 sensor, non brand name sensors don't work with the software or gauges. Cheaping out on a low cost O2 sensor does not make sense.
I don't recommend having a permanent gauge as they are too distracting (especially the sweeping type) but some people do and its a personal choice. Once the carbs are running correctly there is no need to have it mounted.
Last edit: 11 May 2024 10:25 by Injected. Reason: info
The following user(s) said Thank You: Zaddict
10 May 2024 20:27 - 11 May 2024 06:04 #898873 by F64
Replied by F64 on topic Wideband O2 kit recommendations?
Yeah, I just use mine when testing. I had the Innovate LM-2, but mine had a habit of shutting down then restarting. It was a pain.
I went to www.14point7.com and got his SLC FREE 2. I ended up getting 2 of those units.
I wouldn't run mine all of the time as the O2 sensors stick out to the side asking to get broken off.
For $120 each with sensor, it's a pretty good deal. Note: he's located in Canada.
All of SLC FREE 2 build is open sourced. You can build one if you wish.
I stacked mine and put a tripod bushing in the back to be able to mount it to a gopro arm.
www.bhphotovideo.com/c/product/101501-RE...er_Screw_3_8_16.html
There is only one sensor plugged in.
81-KZ440-D2.
LIC, NY
Last edit: 11 May 2024 06:04 by F64.
  • ThatGPzGuy
12 May 2024 05:30 #898916 by ThatGPzGuy
Replied by ThatGPzGuy on topic Wideband O2 kit recommendations?
I use an AFR gauge in my cars and move it around when I tune. They don't need to be permanently installed and you can plug up the O2 sensor bung when not in use. I have not considered using it on my bikes but now that I think about it....
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Zaddict
  • Topic Author
12 May 2024 10:51 #898926 by Zaddict
Replied by Zaddict on topic Wideband O2 kit recommendations?
OK, thanks all. I suppose you're right, I can just mount the sensor and gauge when testing, no need for a permanent mount.
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
12 May 2024 17:34 - 12 May 2024 17:36 #898932 by Injected
If your looking for a standalone gauge your probably going to have to cobble something up. I don't think I have ever seen one that is "motorcycle" specific since not many new bikes use carbs.
You can buy gauge mount pods designed for cars, but they would need to be modified to mount on a handlebar. The rest is pretty straight forward, just wiring and splicing into your harness.
I have not used my new AFR gauge yet, just wondering if it can survive the extra vibration that a bike makes VS a car.
Last edit: 12 May 2024 17:36 by Injected. Reason: info
  • Wookie58
  • Away
  • Moderator
12 May 2024 23:40 #898936 by Wookie58
Replied by Wookie58 on topic Wideband O2 kit recommendations?
Can you build a rubber mount into your setup ?
  • ThatGPzGuy
13 May 2024 05:00 - 13 May 2024 05:08 #898939 by ThatGPzGuy
I believe there is a wideband AFR that uses your phone as the display. I think that would be perfect. I know of a guy using one, but I can't recall the brand.
edit: Found an example  hyper racing
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Last edit: 13 May 2024 05:08 by ThatGPzGuy.
  • Wookie58
  • Away
  • Moderator
13 May 2024 05:41 #898941 by Wookie58
Nice bit of kit but "a lot of coin" for something you would potentially use very infrequently unless you where running a shop (potentially once you have your jetting sorted it would live in a cupboard !!)
  • ThatGPzGuy
13 May 2024 06:51 #898954 by ThatGPzGuy
Yeah, not cheap but... I have more than one bike and several cars so with the just the additional cost of an O2 sensor bung I could use it all the time.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
13 May 2024 07:18 - 13 May 2024 07:20 #898955 by Injected
I did build in some rubber dampers but there is only so much you can do. Cars have more suspension and tires to smooth out the ride than bikes so it will have to be seen. That is why I like oil filled gauges over plain gauges. The AFR gauge also has a circuit board in it, that is what worries me the most. Since it will only be for limited use I am just hoping it will survive for that short amount of time.
Last edit: 13 May 2024 07:20 by Injected. Reason: sp
  • Zaddict
  • Topic Author
13 May 2024 09:23 #898959 by Zaddict
It's a bargain compared to multiple dyno tuning sessions, or all the time I've already spent blindly swapping jets without quantitative data!
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
The following user(s) said Thank You: ThatGPzGuy, Wookie58
