- Thank you received: 58
Wideband O2 kit recommendations?
- Zaddict
- Enjoying my Zaddiction!
I'm thinking I'd like to install a wideband O2 sensor to help dial in my carb settings for my new Wiseco 615cc setup. I see a lot of slick looking systems out there but it doesn't seem like many (any?) are designed for motorcycles. I'm thinking the gauge would need to be waterproof, and I haven't found any that include mounting hardware. I'm looking for recommendations and/or experiences people have had. Thank you!
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
- Injected
- Thank you received: 557
On the 8th page of my project build I made a gauge cover and mount for a AEM AFR UEGO gauge (self contained gauge and controller)
In the past I have used a Innovate controller kit thru a PC (tuning a alcohol injected drag bike)
I also am doing a DFI conversion using a 14 point seven brand controller with a Mirosquirt ECU. Both setups use Bosch LSU49 O2 sensor, non brand name sensors don't work with the software or gauges. Cheaping out on a low cost O2 sensor does not make sense.
I don't recommend having a permanent gauge as they are too distracting (especially the sweeping type) but some people do and its a personal choice. Once the carbs are running correctly there is no need to have it mounted.
- F64
- 81-KZ440D2
- Thank you received: 399
I went to www.14point7.com and got his SLC FREE 2. I ended up getting 2 of those units.
I wouldn't run mine all of the time as the O2 sensors stick out to the side asking to get broken off.
For $120 each with sensor, it's a pretty good deal. Note: he's located in Canada.
All of SLC FREE 2 build is open sourced. You can build one if you wish.
I stacked mine and put a tripod bushing in the back to be able to mount it to a gopro arm.
www.bhphotovideo.com/c/product/101501-RE...er_Screw_3_8_16.html
There is only one sensor plugged in.
81-KZ440-D2.
LIC, NY
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Zaddict
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- Injected
You can buy gauge mount pods designed for cars, but they would need to be modified to mount on a handlebar. The rest is pretty straight forward, just wiring and splicing into your harness.
I have not used my new AFR gauge yet, just wondering if it can survive the extra vibration that a bike makes VS a car.
- Thank you received: 2385
Can you build a rubber mount into your setup ?If your looking for a standalone gauge your probably going to have to cobble something up. I don't think I have ever seen one that is "motorcycle" specific since not many new bikes use carbs.
- ThatGPzGuy
edit: Found an example hyper racing
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Nice bit of kit but "a lot of coin" for something you would potentially use very infrequently unless you where running a shop (potentially once you have your jetting sorted it would live in a cupboard !!)I believe there is a wideband AFR that uses your phone as the display. I think that would be perfect. I know of a guy using one, but I can't recall the brand.
- ThatGPzGuy
Yeah, not cheap but... I have more than one bike and several cars so with the just the additional cost of an O2 sensor bung I could use it all the time.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Injected
I did build in some rubber dampers but there is only so much you can do. Cars have more suspension and tires to smooth out the ride than bikes so it will have to be seen. That is why I like oil filled gauges over plain gauges. The AFR gauge also has a circuit board in it, that is what worries me the most. Since it will only be for limited use I am just hoping it will survive for that short amount of time.
- Zaddict
It's a bargain compared to multiple dyno tuning sessions, or all the time I've already spent blindly swapping jets without quantitative data!Nice bit of kit but "a lot of coin" for something you would potentially use very infrequently unless you where running a shop (potentially once you have your jetting sorted it would live in a cupboard !!)
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
