sunday shopping list...
sand blaster -cheaper depot version
spray gun.....maybe a gravity feed kit with some goodies to boot....
jasco..aircraft..and some other strippers...
primers...sand bags...wire wheels,sand blocks ,s papers,naval jellies,wire brushes,gloves,tarp, and rustolleum metal and plastic primers and some dupli test colors....
also settled on this guys 2 hr dvd to watch one night for any little tips...really in depth no nonsense appraoch
he can be googled under " Len Stuart Spray Painting 101 DVD" seems like what i'm after...
so...OMR...what about the oven cleaner soak...brake fluid soak????any chems even able to move the surface coats...or was it very strong rim paint.....
i mental noted to
use a pan and rag and soak my side covers,tailpeices,and small bracketts in lotts of brake fluid over night
to use aircraft stripper and wrap the frame in plastic untill it has done it's best on a layer ...then pressure waswh and re-do......
gonna maybe see if i canb get set up to start stripping next sat.....
