adbz650 wrote: ...coils on bike (melted ones) getting 2.3ohms, ...
4 ohms... suggested by Newtronic for the electronic ignition.
That could explain the melt down during normal running. The Newtronic dwell may be too long for 2.3 ohm coils.
You can use the Emgo 4-ohm coils. They are inexpensive and have been reported as pretty good. But I think they come with plug wires attached already. You have to cut them to length and put ends on them.
You can probably alos use Dyna 5 ohm coils safely... maybe even 3-ohm coils if Newtronic says 3 ohms is ok.
In general, using coils with higher ohms is "safe" in that it won't damage anything. But they charge slower, so you want to make sure you have enough dwell... and I think the Newtronic has plenty.
The 4.9 ohm coils will work with plug wire extenders, but that can get troublesome in the long run for reliability. And the fact that they measure 4.9 could mean they are getting old beyond their service life.
