GPzMOD750 wrote:
ahot1968 wrote: I have replaced all components of the charging system the sator is now pushing 60-80 volts at 4000 RPMs
The Electrosport I'm using was doing 90+ @ 4-5k iirc.
I thought I recall you were testing at 5000 RPM. But I think the manual specifies 4000 RPM, and that is the only RPM at which a number is given. The tests should be done at 4000 RPM, and tachometers can be significantly off, so that is a factor to consider as well.
1-phase (two-wire) stators should have about 75 VAC at 4000 RPM.
3-phase(three-wire) stators should have about 50 VAC at 4000 RPM.
Those are typical values.
Open load tests can confirm when an alternator (rotor and stator combined) is bad, but not necessarily confirm that it is good.
A load test is needed, with heat and time involved, to really know for sure if an alternator is good. That is not an easy test to do.
