  • Page:
  • 1
  • 2
1977 Tail light lost voltage Brake works fine 16 Sep 2016 11:07 #742508
  • galaxian
  • galaxian's Avatar Topic Author
  • Thank you received: 0
Hi All,
My tail light red wire has lost all voltage...the brake light though works fine.
My question is if the red wire goes to the ignition switch how do i test it? Is it as simple as seeing if there is a connection between BLUE and RED?
Help
1977 KZ1000A1, 1979 KZ650 C3
1977 Tail light lost voltage Brake works fine 16 Sep 2016 17:49 #742554
  • Kapahulu
  • Kapahulu's Avatar
  • Thank you received: 44
The main wiring harness connects to a smaller harness going from under the seat to the tail light. The harness might be shorted out or a wire might be disconnected. You can unplug the connectors at the tail light and pull the small harness out to check it.
2strokeworld.com
1977 Tail light lost voltage Brake works fine 16 Sep 2016 18:09 #742559
  • galaxian
No offense but did you see my question?
1977 Tail light lost voltage Brake works fine 16 Sep 2016 18:34 #742561
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Thank you received: 667
galaxian wrote: Hi All,
Help
Hi galaxian,
We'd say yes. When the ignition sw. is ON blue and red is closed according to Clymer manual.
Disconnect the ignition sw. pin connector and test for continuity between blue and red with sw. ON. No continuity = bad sw.
Good Ridin'
slmjim & Z1BEBE
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
1977 Tail light lost voltage Brake works fine 16 Sep 2016 19:41 #742571
  • Kapahulu
  • Kapahulu's Avatar
galaxian wrote: No offense but did you see my question?
Hi Galaxian,
Yes however i was thinking there might be an easier solution, e.g. finding an unplugged connector or a frayed wire.
2strokeworld.com
1977 Tail light lost voltage Brake works fine 16 Sep 2016 19:45 #742572
  • galaxian
Did that before posting. But thanks for your suggestion. Im not trying to be rude but this site has grown over the years and search does quite work well. I hate wadding through the same questions so i was being as specific as possible.
1977 Tail light lost voltage Brake works fine 16 Sep 2016 19:46 #742573
  • galaxian
Slimjim,
I have the switch ON
Put one probe onto the red the other on the blue 1.9 ohms. I didnt pull the wired out of the ignition switch. Does that negate the test?
Last edit: by galaxian.
1977 Tail light lost voltage Brake works fine 16 Sep 2016 20:22 #742576
  • slmjim+Z1BEBE
Yes.
Switch has to be out of the circuit to test continuity between blue & red with switch ON.
If it's like a Z-1 the pin connector is in the headlight bucket..
Good Ridin'
slmjim & z1bebe
1972 Z1 x2
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: by slmjim+Z1BEBE. Reason: Correction
1977 Tail light lost voltage Brake works fine 16 Sep 2016 22:04 #742581
  • galaxian
Now im getting 7 volts at the tail....not sure what to do about it yet. As far as pulling the pins they are in the pod where the key inserts.
1977 Tail light lost voltage Brake works fine 16 Sep 2016 22:07 #742582
  • Thank you received: 2098
galaxian wrote: Did that before posting. But thanks for your suggestion. Im not trying to be rude but this site has grown over the years and search does quite work well. I hate wadding through the same questions so i was being as specific as possible.
being as specific as possible should imo include make and model of whatever 1977 motorcycle is being referenced.
While it may sometimes be possible to comb through another member's various earlier postings among other threads in an effort to help guess what make and model is being asked about, I suspect that many members who are normally generous toward posting helpful replies will simply pass and move on without bothering to comb.
It's easy to put the information in your signature where it shows in all posted messages, past and future. And the signature may be changed whenever and as often as desired.
If wanting a signature showing information about the bike in posted messages, it's easy to do. Here's how:
Good Fortune! :)
Last edit: by Patton.
1977 Tail light lost voltage Brake works fine 16 Sep 2016 23:20 #742584
  • galaxian
Mia culpa....Kz1000 1977
1977 Tail light lost voltage Brake works fine 17 Sep 2016 03:46 #742589
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1635
1000A? I would back probe the ignition switch connector for voltage. key on. The problem could be the soldered connections inside the Ign switch. assuming it's not a problem with the tail light harness. If the Ign sw tests fine, then I guess you'd have to check the harness.
Edit: I would jiggle or move the pigtail around while probing. and do the same at the tail light harness connector.
Last edit: by martin_csr.
  • Page:
  • 1
  • 2
