  • Page:
  • 1
  • 2
gpz1100 not wanting to turn over fast when hot 19 Jun 2016 14:07 #732019
  • Coast Steve
  • Coast Steve's Avatar Topic Author
  • Thank you received: 22
81 gpz 1100
1982 Kawasaki Eddie Lawson S1 (1136cc race replica clone.)
gpz1100 not wanting to turn over fast when hot 19 Jun 2016 14:48 #732025
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Thank you received: 2598
Take the starter out and see what ya got.
gpz1100 not wanting to turn over fast when hot 19 Jun 2016 14:49 #732026
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
As an easy diagnostic, maybe get it hot then use some decent jump leads from a charged car battery : +ve straight to the starter terminal, -ve grounded to the engine on an unpainted part. If your problem disappears temporarily then clean/replace battery leads on both sides and the starter solenoid.
Heat seizure making the motor tight is another less likely possibility.
starter clutch on the 900/100/1100 easy, much harder on the 550/650/750's
Are your carbs badly out of balance?
Last edit: by Tyrell Corp.
gpz1100 not wanting to turn over fast when hot 20 Jun 2016 10:54 #732128
  • Coast Steve
Carbs were synced for me right before the bike shipped.
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 02:50 #732204
  • JoHNY
  • JoHNY's Avatar
  • Thank you received: 6
If it is the timing it's an easy fix. Covers and tensioner off, get it TDC and lift the chain from the sprockets. You need to count exactly 43 links (43 I think) from head surface to head surface. This is the crucial part, if this is wrong by one link you'll get your symptoms. If your chain doesn't lift from the sprockets just remove the cam caps.
Mr Haynes is clear on this
Kawasaki Z750P7 Spectre, Triumph Daytona 955i, Honda CBR1000FN
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 06:40 #732230
  • SWest
  • SWest's Avatar
  • 10 22 2014
Was looking at a rebuild kit last night when I was looking for a fuse block for another member. I should have saved it. It comes with bushings and everything else. B)
eBay
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 14:36 #732279
  • SWest
  • SWest's Avatar
  • 10 22 2014
No eBay APP ID and/or Cert ID defined in Kunena configurationI saved it on my lap top in the living room. :)
Now if they only have one for my Z1. :unsure:
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 15:09 #732281
  • SWest
  • SWest's Avatar
  • 10 22 2014
I found one. :woohoo:
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 15:36 #732287
  • Coast Steve
Awesome,
Let me get my manual and figure out what it is.
Been super busy in the shop building. No time for the bike.
gpz1100 not wanting to turn over fast when hot 21 Jun 2016 18:21 #732313
  • Coast Steve
Hey, are these the same manual?
Z1100GP
and
GPZ1100
  • Page:
  • 1
  • 2
