  • Page:
  • 1
1982 GPz750 won't start 30 Jun 2015 11:43 #678851
  • Richardson
  • Richardson's Avatar Topic Author
  • Thank you received: 0
Hey guys, looking for a little help with my '82 GPz 750 ... Turn the key, nothing happens at all. No lights come on, no whirrs or clicks or buzzes, nothing. Did this before and I replaced the main fuse and hey presto, it worked. This time, no dice. Replaced the other two fuses for good measure. Nothing.
The battery is fully charged, I have checked it twice since this started.
Any obvious culprits before the multi meter comes out?
Thanks
1982 GPz750 won't start 30 Jun 2015 11:54 #678852
  • mopguy
  • mopguy's Avatar
  • Thank you received: 168
I would clean all contacts with Deoxit, and replace all fuses, sometimes fuses look good but they are not, and hopefully this is all you need.
1982 GPz750 won't start 30 Jun 2015 18:25 #678876
  • JR
  • JR's Avatar
  • Thank you received: 429
+1
Also check for
Loose or bad connection at the negative battery post or ground.
1982 GPz750 won't start 30 Jun 2015 19:05 #678880
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
  • Thank you received: 376
Same thing happened to me at a gas station. It was the main fuse. Easy fix but you should always carry spares. Better yet. replace the glass fuses with automotive blade type fuses.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
1982 GPz750 won't start 30 Jun 2015 20:30 #678891
  • bountyhunter
  • bountyhunter's Avatar
  • Thank you received: 337
Fuses, battery contacts or battery cable connections. If no luck, ignition switch.
1982 GPz750 won't start 01 Jul 2015 05:24 #678922
  • Tyrell Corp
  • Tyrell Corp's Avatar
  • Thank you received: 260
bountyhunter wrote: Fuses, battery contacts or battery cable connections. If no luck, ignition switch.
yes, also handlebar engine killswitch, the tacho needle should twitch when the ignition is ON and it is switched to RUN, if not test light battery + live going to coils . Also check for continuity between main fuse in and out of ignition switch to other fuses.
  • Page:
  • 1
