  • Page:
  • 1
  • 2
Electrical problem post burying wires 21 Dec 2014 03:23 #656602
  • Thank you received: 2098
!Seymore wrote: Why do we have 2 threads for one problem? Can a Mod/Admin consider combining them? Thanks...
kzrider.com/forum/5-chassis/596730-repla...stock-bars-with-what
kzrider.com/forum/4-electrical/596751-el...m-post-burying-wires
Posts about wire burying have been moved from the chassis forum topic to the electrical forum topic.
Good Fortune! :)
The following user(s) said Thank You: !Seymore
Replacing stock bars with what? 21 Dec 2014 06:21 #656608
  • martin_csr
  • martin_csr's Avatar
  • Thank you received: 1621
my mistake. never mind. :blush:
Last edit: by martin_csr.
Re:Electrical problem post burying wires 21 Dec 2014 15:00 #656636
  • Britome
  • Britome's Avatar Topic Author
  • Thank you received: 0
So before i pulled the wires out from the bars, I tested each wire where it connects to the housing and then the other end. All wires are giving me a beep on the multimeter. Are you sure I need to pull them out and reinsulate/shield. If that was the problem then they wouldn't test out. Right?
Re:Electrical problem post burying wires 21 Dec 2014 15:13 #656638
  • Britome
I just pulled out and reinspected. No insulation is broken on individual wires.
Re:Electrical problem post burying wires 21 Dec 2014 15:56 #656642
  • !Seymore
  • !Seymore's Avatar
  • Ride on...
  • Thank you received: 61
A 2nd layer of insulation will never hurt, So, did you test impedance between the wires and the bar? ...not continuity, while the wires were in the bars?
C.
79' KZ650-D2 [fsm] (Max)
83' KZ750-F1 LTD [clymers] (Kay)
82' KZ1100-D1 Specter (another project)
78' KZ650-B2a (J&H, A Project)
91' KZ1000-P (P = parts)
Re:Electrical problem post burying wires 22 Dec 2014 10:06 #656717
  • Britome
Hmmm. I did not. I'll just shrink wrap them and put Em through
Re:Electrical problem post burying wires 10 Jan 2015 07:42 #658253
  • Britome
Everything is shrinked and tucked away. All works except hazards (not sure if they ever worked) and the headlight. I tested the headlight and it is good. I think my best bet is to run new wiring from the light to the battery. I don't care about switching from hi to low beams.
Any advice as to how to enable it to be switched so that it shuts off when not running?
Re:Electrical problem post burying wires 10 Jan 2015 08:44 #658272
  • Thank you received: 2829
You may want to think twice about not having high and low beams; eliminating the ability to switch could get you hurt. Here's why - Years ago I was riding along a twisty country road on a very dark night; I had my high beam on. The high beam filament in the bulb broke and pooof - INSTANT darkness! I immediately switched to low beam and all was good. If I hadn't been able to switch to low beam I definitely would have gone off the road before I could stop. Ed
Re:Electrical problem post burying wires 11 Jan 2015 06:56 #658401
  • Britome
Ok. And how where in the harness do you recommend I tap in?
Re:Electrical problem post burying wires 11 Jan 2015 07:14 #658402
Britome wrote: Ok. And how where in the harness do you recommend I tap in?
Tap in for what? :unsure:
Sometimes an accessory connector may be available from the stock wiring harness.
And may appear on the wiring diagram.
The accessory connector may be the female half of a bullet connector.
And usually intended to furnish battery-positive voltage when the ignition switch is turned ON). Aka switched battery positive, which may be abbreviated to something such as Switchd.batt+,
The female connector might be underneath a side cover, or underneath the fuel tank, or inside the headlight shell.
Good Fortune! :)
Last edit: by Patton.
  • Page:
  • 1
  • 2
