  • Page:
  • 1
  • 2
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 07:26 #647746
  • stevie g
  • stevie g's Avatar Topic Author
  • Thank you received: 0
Hi, I've been looking for the wiring diagram for kawasaki kz1000 M1 that was on here in the filebase. It seems to have disappeared. Can someone point me to where it is please, thanks Stevie.
stephen g mackay
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 08:46 #647753
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
  • Thank you received: 304
You are correct...I uploaded many of the wiring diagrams for all the four-cylinder models back in the mid-2000's and all are now gone. Maybe Stein will step in and look for back-up files.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 09:03 #647755
  • H1Vindicator
  • H1Vindicator's Avatar
  • Thank you received: 45
Buy the Kawasaki factory service manual, then scan the wiring diagram.
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 10:17 #647760
  • Thank you received: 2098
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 10:50 #647762
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Thanks Patton...where are these older uploads now? In the general category rather than under a specific model number?
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:15 #647767
A FILEBASE Search for KZ1000M1 should include a clickable reference to the downloadable wiring diagram.
Broader FILEBASE searches such as KZ1000 should also include the same reference among lots of other references.
Can also insert a year in the search term, such as 1978 KZ1000 or 1978 KZ1000M or 1978 KZ1000M1.
Good Fortune! :)
Last edit: by Patton.
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:18 #647768
  • stevie g
I've got a manual on it's way to me but that's in a few days. Just wondered where it had gone. There was also another article about the M1, that's also gone.
stephen g mackay
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:24 #647770
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Patton wrote: A FILEBASE Search for KZ1000M1 should include a clickable reference to the downloadable wiring diagram.
Good Fortune! :)
The reason I ask is that if you go to Filebase and look under KZ documents and then under 'fours', there are only a few documents listed...I suspect stevie g looked that route, as did I. That is where they used to be, IIRC. Also, if you look under the drop-down menu with the Filebase link open and select KZ1000...very few documents are there. So, unless one uses the general 'Search' under filebase, many formerly easy-to-access documents are hidden.
Michael
Alvin, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: by Mcdroid. Reason: clarity
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:30 #647771
  • stevie g
Yea that's the route I took and come up with nothing.
stephen g mackay
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:30 #647772
stevie g wrote: I've got a manual on it's way to me but that's in a few days. Just wondered where it had gone. There was also another article about the M1, that's also gone.
KZr has many forum posts that mention the M1.
What specifics are in the post sought? Approximate posting date? Author?
Often, an advanced forum search will produce the post, but key words are usually needed to narrow the search so that only posts containing the key words are produced.
Good Fortune! :)
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:33 #647773
  • stevie g
It was in the filebase, and it isn't there now as previous guy said.
stephen g mackay
kawasaki kz1000 M1 wiring diagram 16 Sep 2014 11:40 #647775
Good Fortune! :)
That's why I use "Search Downloads" instead of "Select Category."
Good Fortune! :)
  • Page:
  • 1
  • 2
