seanof30306 wrote:
bountyhunter wrote:
"self cancelling" blinkers on a bike are usually implemented elctronically by using a 555 timer set up as a "power source" that will provide the +12V to the blinkers for a set time period after you turn the switch on, and then cut off. You have to turn the switch off and then back on and it resets and works again. It's fairly easy to implement if you are electronically oriented.
Hehehe, those would appear to be the operative words.
bountyhunter wrote:
I just put a beeper on mine to remind me to turn them off.
That is a great, simple solution that hadn't even occurred to me.
Can you tell me what buzzer you used, and how you wired it up? It'll probably be over my head, but I have a buddy who is much more electronically oriented than I am.[/quote]
I bought whatever little 12V buzzer they had at radio Shack, and used some double sided foam sticky tape to stick it on top of the steerin g stem.
Wiring is pretty easy: you need two diodes like 1N4001 (Radio Shack or FRY's will have them). Hook the anode (positive end) of each diode to the +12V hot wire that connects to each of the front turn signal light. Tie both cathode (negative) ends of the diodes together and use that point to go to the + lead of the 12V buzzer. Ground the other side of the buzzer.
On mine, the front turn signal wires are inside the headlight cowl so it's pretty easy to get at the wires.
