You could try this:
Pin 85 on the relay should go to the battery negative or a ground wire.
But eventually you will have to fix the fuse holder and ignition switch. I would splice in a weatherproof mini-spade fuse-holder in place of the 20 A fuse in the fuse box. You can get ignition switches from Dennis Kirk, but try Z1enterprises first.
Post edited by: loudhvx, at: 2007/07/16 13:34
