what to do ?
  • zirafin
  • zirafin's Avatar Topic Author
Re: what to do ?
23 Mar 2016 06:22
#716918
yes
  • KZB2 650
  • KZB2 650's Avatar
Re: what to do ?
23 Mar 2016 06:37
#716919
Maybe I missed it but one of the top recommendations on here is oiling up the advancer and by the rust in the picture of it thinking you should add this to your list. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • loudhvx
  • loudhvx's Avatar
Re: what to do ?
23 Mar 2016 08:46
#716935
Have you tried the water test on the exhaust to make sure you are running on 4 cylinders? The water should dance off of each pipe the same way.
  • zirafin
Re: what to do ?
23 Mar 2016 08:57
#716937
yes i try ,all pipe are hot and then the engine is worm its boils and dance away . but i think maybe the spark is weak and is not good . tomorrow i will try to mace video of water ;)
  • loudhvx
  • loudhvx's Avatar
Re: what to do ?
23 Mar 2016 09:33 - 23 Mar 2016 09:34
#716947
Also, what is the needle clip setting?
Have you tried to open throttle while removing choke (both very slowly so it doesn't die)?
Even if the advancer was stuck at F, it should be able to get to 2000 RPM.
Last edit: 23 Mar 2016 09:34 by loudhvx.
  • zirafin
Re: what to do ?
23 Mar 2016 10:46 - 23 Mar 2016 10:52
#716958
yes i try this its hols just a little. open throttle while removing choke.
no i do not no needle clip settings , because it was cleaning the other person.
i tested my spark plug is only 2 of 4 is working nice rest vas badly but i got red spark not blue:( video
and i tested cylinder 1 and 2 for spark.
Last edit: 23 Mar 2016 10:52 by zirafin.
  • zirafin
Re: what to do ?
24 Mar 2016 03:22
#717068
one mechanic say to check carburetor if the needles is closing float petrol?
if u know about it can u give me how to check???
  • zirafin
Re: what to do ?
25 Mar 2016 06:58
#717260
iam so sad and pist on my z550 its do not want to work so i tace away air box again and start to order drill bit for drilling the pilot jet and main jet.
i copy from forum this :
I would go from 32 idle jet to 37 idle jet.
Get adjustable needles and set them to 3rd or 4th clip from the top, and I'd start with 100 or 102 mains.
ok if i drill the pilot jet 37 , main jet at 99.1 and needles if adjust can my be adjust?
Attachment IMAG1333-2.jpg not found
  • loudhvx
  • loudhvx's Avatar
Re: what to do ?
25 Mar 2016 08:21
#717282
That is the factory setting on the factory needle, so it seems original.
I doubt you should start messing with jetting. It is not time to do that yet. Ignition seems more urgent.
I did not see the water test on the video.
  • zirafin
Re: what to do ?
26 Mar 2016 08:53 - 26 Mar 2016 09:33
#717418
hi i have no time to mace video , i just tace off ignition coils and tested the wires its resistance 4.72 om but how to test ignition coil using multimeter? on coil is + and -
and ho to test ignition pickup coil .i will try tomorrow to mace video of water test
if u can give pictures and readings of what i need to see in multimeter.
Attachment IMAG1343.jpg not found
Attachment IMAG1339.jpg not found
Last edit: 26 Mar 2016 09:33 by zirafin.
  • zirafin
Re: what to do ?
26 Mar 2016 11:55
#717440
power 12.5 v is til coils .
one more pic of test coil
Attachment IMAG1344.jpg not found
  • zirafin
Re: what to do ?
27 Mar 2016 02:20
#717526
It's water test 4 cilinder do not working . ;(
I swap spark plug I test resistor on ignition coils it's same but don't work.
