Making a Kawasaki Z1 race ready. Again
27 Jan 2012 09:41 - 27 Jan 2012 09:48 #500302 by LarryC
Replied by LarryC on topic Making a Kawasaki Z1 race ready. Again
Attachment dog.jpg not found
The purpose of the back cut is to put an angle on the dogs. That helps them ramp into each other, pulling them into engagement. That's the angle I was referring to.
Takes one steady hand to maintain that angle perfectly on every dog so they share the load from the crankshaft. :)
On a drag bike, every other dog is removed on certain gears as well. Not the hot setup for street because of the back lash introduced. Also, only the up shift side gets cut. On a road racer it's both sides.
Larry C.
Last edit: 27 Jan 2012 09:48 by LarryC.
27 Jan 2012 11:42 #500319 by dbsuperbiker
Replied by dbsuperbiker on topic Making a Kawasaki Z1 race ready. Again
yes, that's the angle.
no, it's not easy.
yes, I have a steady hand.
I have cut these dogs by hand and disassembled the same gear set after some time and can tell by the wear patterns that it is successful.
  • 531blackbanshee
  • Vendor
  • Vendor
27 Jan 2012 12:24 - 27 Jan 2012 12:33 #500324 by 531blackbanshee
Replied by 531blackbanshee on topic Making a Kawasaki Z1 race ready. Again
when i was at Joe Mondello's head porting technical school he said that his friends called him
"the human bridgeport".
now i think that maybe arthurs friends also call him the human bridgeport :lol: .
but joe did some of his own dental work and ground his teeth for fillings and filled them!!!!!!!!
arthur,have you ever done your own dental work?
nice work arthur thanks for sharing.
Last edit: 27 Jan 2012 12:33 by 531blackbanshee.
27 Jan 2012 13:51 #500328 by Patton
Replied by Patton on topic Making a Kawasaki Z1 race ready. Again
Out of my league, but here's an exaggerated illustration of back-cut angles on the dogs. :)
Good Fortune! :)
The following user(s) said Thank You: Bad Kaw
27 Jan 2012 14:04 #500331 by Patton
Info and pic from KZZONE --
TRANSMISSION UNDERCUTTING
Undercutting a transmission involves machining angels on the engagement dogs and slots to prevent the transmission from jumping out of gear under load. There are three types of undercuts available from APE
Racecut...
This cut is performed on the side of the dogs that are loaded on acceleration. Recommended for hot street bikes and drag racers, dwarf cars, etc.
Up and down cut....
Both sides of the dog are cut to also prevent jumping out of gear on down shifts. Recommended for road Racing.
kzzone.com/trans.html
Good Fortune! :)
  • Kidkawie
  • I bleed premix
27 Jan 2012 18:14 #500358 by Kidkawie
Replied by Kidkawie on topic Making a Kawasaki Z1 race ready. Again
dbsuperbiker wrote: the forks are '86 ZX10, gutted of the antidive and re-valved. They are stiffer than the orig forks...no more high speed wobble, but require extensive tuning to suit each track and keep the front end from chattering under high cornering speeds.
Vintage rules when bike refurbished allowed for same manufacturer's lower slider fork up to 40mm to be substituted in place of orig.
No, they are not close to modern fork performance...and very hard to tune, but the bike does not wobble
Great articles, thanks for contributing!
I'm trying to get the best performance out of my stock 75 by tuning what's there. The first time I had my bike up to 80-85mph I nearly wet my pants from the dreaded weave. I notice it alot on 45-50 curves, and sometimes on high speed straights. Was thinking of installing some RT emulators. Any input on that? Stock bike, tapered neck bearings, good stock swingarm bushings, no frame bracing. I have a lathe and tune my own MX suspension..just baffled by this.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
27 Jan 2012 19:53 - 27 Jan 2012 19:55 #500376 by Patton
Kidkawie wrote: ...trying to get the best performance out of my stock 75 by tuning what's there. The first time I had my bike up to 80-85mph I nearly wet my pants from the dreaded weave. I notice it alot on 45-50 curves, and sometimes on high speed straights. Was thinking of installing some RT emulators. Any input on that? Stock bike, tapered neck bearings, good stock swingarm bushings, no frame bracing. I have a lathe and tune my own MX suspension..just baffled by this.
Some links to info about speed wobble:
www.kzrider.com/forum/5-chassis/485651-r...vice-for-sure#485651
www.kzrider.com/forum/5-chassis/479527-r...00-ltd-wobble#479527
www.kzrider.com/forum/5-chassis/476857-re-speed-woble#476857
www.kzrider.com/forum/5-chassis/476841-re-speed-woble#476841
www.kzrider.com/forum/5-chassis/467462-r...peed-wobble-o#467462
Weave may be a different issue than wobble, perhaps due to over-tight steering head bearings, among other possible reasons.
Good Fortune. :)
Last edit: 27 Jan 2012 19:55 by Patton.
28 Jan 2012 08:36 #500423 by turboguzzi
Replied by turboguzzi on topic Making a Kawasaki Z1 race ready. Again
dbsuperbiker wrote: I dont use a stone because of its wear, loses the crisp shape.
Hi-speed dental motor/coaxial cable/carbide burrs.
As a life long artist, I have good control. Even at that, bright light, strong glasses, a vernier caliper, machinist dye, and testing the fit throughout the process makes it work out fine.
Depending on the condition of the patient, operation takes about 7 hours. Too much to do at one sitting, usually about 3 sessions.
I have done this successfully dozens of times over the years on my bikes and for others.
Luckily, the GPZ750 cluster comes undercut from the factory... so didnt have to sweat here :)
What sort of art do you do?
29 Jan 2012 20:44 #500745 by dbsuperbiker
As a child, I oil painted...always drawing too.
My major in College was advertising design, I dropped out as a junior to open a motorcycle shop :)
Craft projects of every size, kind, and challenge are fun to me.
07 Feb 2012 01:04 #502478 by LarryC
531blackbanshee wrote: when i was at Joe Mondello's head porting technical school he said that his friends called him
Joe left us last year. That's sad :(
Larry C.
  • 531blackbanshee
  • Vendor
  • Vendor
07 Feb 2012 12:24 #502558 by 531blackbanshee
Joe left us last year. That's sad :([/quote]
sad indeed.
to say that he was awesome is an understatement .
  • mtbspeedfreak
  • Topic Author
04 Jun 2012 16:46 #526852 by mtbspeedfreak
Replied by mtbspeedfreak on topic Making a Kawasaki Z1 race ready. Again
Hey Arthur, you still around these parts?
2000 ZRX 1100
1976 KZ 900- Daily Driver
