Seat
21 Jan 2023 18:19 - 21 Jan 2023 18:22 #879133 by allfixed
Seat was created by allfixed
I'm looking for a good condition stock seat for my 78 KZ1000A
the flat type with a good pan would be great.
I'm currently using a KZ900 stock seat I will sell if I find the right seat.
Milwaukee wi.
Last edit: 21 Jan 2023 18:22 by allfixed.
  • hardrockminer
22 Jan 2023 04:44 #879141 by hardrockminer
Replied by hardrockminer on topic Seat
Are they not the same except for the cover?
22 Jan 2023 08:10 #879152 by allfixed
Replied by allfixed on topic Seat
Very close, mine is an early 900 seat the pan is a tad different it fits works fine and the cover pattern is different.
Milwaukee wi.
  • hardrockminer
22 Jan 2023 14:20 #879170 by hardrockminer
Perhaps all you need is a new cover.  They are fairly common.  Here is one source.
www.z1enterprises.com/seat-cover-kz1000-...Early/KZ1000-A2/1978
22 Jan 2023 16:03 - 22 Jan 2023 16:10 #879177 by Mikaw
Replied by Mikaw on topic Seat
‘76-‘77 Kz900A and the ‘77-‘78 Kz1000A all used the same seat. There are only two flat seat patterns. Z1 and the KzA’s up till 1978. If yours is different then it’s not original. The pans are different also. The Z1 pan has the lock latch in the center. The KzA’s it is off to the left side. LTD ‘76-‘80 pan and cover are stepped. Then you get into the D1 and D3 seat, flattish but a third pattern. Also the MKII is similar to the D’s without a sectioned side panel.
Last edit: 22 Jan 2023 16:10 by Mikaw.
23 Jan 2023 03:18 - 23 Jan 2023 04:03 #879193 by cmore
Replied by cmore on topic Seat
Fun fact - the 78 KZ1000 A model seat has a unique (78 only) pattern as seen in this image - current ebay item 275637727798 - It is similar in appearance to the Z1 pattern but different
Another 1978 A model difference as compared to the 1977 model is the addition of a spot welded seat rod catch
1976 & 1977 KZ900 and 1977 KZ1000 A had the same seat cover but different battery vent hose decals - see ebay item 203253161255
Last edit: 23 Jan 2023 04:03 by cmore.
24 Jan 2023 13:21 #879236 by LukasLee
Replied by LukasLee on topic Seat
I have one that you may be interested in, I tried to PM you but I get a message saying something to the effect that I should contact the site administrator, when I try to contact him I get the same message. Any help would be appreciated.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
  • Street Fighter LTD
  • Online
  • Moderator
24 Jan 2023 14:01 #879243 by Street Fighter LTD
Replied by Street Fighter LTD on topic Seat
Use his email
all-fixed@wi.rr.com
24 Jan 2023 15:43 #879252 by Mikaw
Attachment not found
Partzilla shows 2 part number 53001-119 and 53001-1009. Based on my research 53001-119 is correct for the Kz900/Kz1000 through 1978. Is it possible that the 1009 seat is the Canadian/EU model?
24 Jan 2023 16:40 - 25 Jan 2023 06:53 #879256 by allfixed
Thanks all
I purchased the one on ebay shown earlier in this post.
It's ok but a little scabby, I'd be interested in seeing others avail nicer.
Mine is a 78A as mentioned earlier it has the 3 rows of rectangles I'm looking for. I have a 900 seat to sell  with the rectangles down the center
this is the seat I have on my 781000A now
Milwaukee wi.
Last edit: 25 Jan 2023 06:53 by Street Fighter LTD.
24 Jan 2023 16:48 - 25 Jan 2023 06:54 #879258 by allfixed
This is the style I've seen on the 78 kz1000As  I've seen and I'm wanting for mine
Milwaukee wi.
Last edit: 25 Jan 2023 06:54 by Street Fighter LTD.
24 Jan 2023 17:12 #879260 by allfixed
What do you have? I get the same message when I try to pm you?
email me @ all-fixed@wi.rr.com
Milwaukee wi.
