1978 kz750 smoke
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: 1978 kz750 smoke
23 May 2015 08:47
#673310
Dry test 50 psi wet test over 200 psi. All other pots around 150 psi, engine tested cold.
Attachment 14323944613566.jpg not found
New pistons, rings and rebore time at 45 000 miles? maybe not.
gpz750 had only done about 800 miles in previous 10 years, I've done about 500 miles now in a month after recommissioning it and it runs great, I will retest compression soon. I think the rings were gummed and I'm hoping the solvent soak and thrashing will improve or clear the problem.
You've had my advice, what I try firstly in the same situation...
  • Soxx4u
  • Soxx4u's Avatar Topic Author
23 May 2015 09:07
#673313
Thank you for the help I should be getting the rings on Wednesday. Just pulled the motor and will start disassembly. I'll kepp you guys up to date with what I find inside
  • Tyrell Corp
23 May 2015 09:40 - 23 May 2015 09:53
#673318
ok good luck , you seem to know exactly what you are doing here. ;)
Usually stuffed bores/rings would yield blue smoke, perhaps with some exhaust smoke coming out of the oil filler cap caused by blowback gases. On aircooled motors white smoke is usually condensation....
The other point being if the bore is damaged beyond honing, unless you can find another servicable block - or press a new liner in, you'll be needing oversize piston(s) and rings anyway.
Last edit: 23 May 2015 09:53 by Tyrell Corp.
  • Soxx4u
26 May 2015 19:01
#673939
Update... I pulled the motor. Tore into it and found that my oil ring broke in three pieces. One is in the crank case hopefully I can find it without splitting cases. Pistons look good cylinder walls look good. Thank you all for your help.
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 May 2015 19:45
#673942
Thanks for the update. B)
  • Tyrell Corp
27 May 2015 07:02
#673974
I'm puzzled that an oil ring has broken and part of it escaped without damaging the cylinder wall... are the top compression ring gaps and piston / bore clearance within spec? No blue smoke or fouled plug, just white smoke and low compression from a broken oil scraper ring. :unsure:
Is this a 750/4? Pics would be interesting...
The following user(s) said Thank You: missionkz
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 May 2015 07:46
#673981
I made a suggestion on the 81 KZ 440 thread above this one. I suggest it be done in this case as well.
  • Soxx4u
27 May 2015 08:58
#673993
As I was pulling the cylinder off the piece of the oil ring fell down did not happen when it was running. I do not know bore spec. Everything looked tightas I was disassembling. Here are pics of what I have done
Attachment image.jpg not found
  • Soxx4u
27 May 2015 09:04
#673994
Attachment image-2.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
27 May 2015 09:07
#673995
That looks like a secondary ring. Do the bore test and with new rings if within spec you should be good to go. A small piece in the pan shouldn't be a problem. The strainer and filter (if you have one) should keep it out of the oil galleys.
  • KZB2 650
  • KZB2 650's Avatar
27 May 2015 11:31
#674022
Am wondering since you have it that far if you should pull the pan and look for that piece .... you could clean all the sludge and gasket material you probably dropped out at the same time..... and then you can wonder about doing something to the head.... I swear its never ending !! :laugh:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • bountyhunter
  • bountyhunter's Avatar
27 May 2015 12:40 - 27 May 2015 12:42
#674033
KZB2 650 wrote: Am wondering since you have it that far if you should pull the pan and look for that piece .... you could clean all the sludge and gasket material you probably dropped out at the same time.....
big +1 on cleaning the pan. You won't believe how much sludge will be in there. And you can "hose upwards" with brake cleaner spray and clean the underside of the internals while the pan is off.
You will want to get the valves turned and replace the seals while you are doing this, also the O rings on the oil feed pipes going up to the head. Guess how I learned that...... :ohmy:
Last edit: 27 May 2015 12:42 by bountyhunter.
