Radical streetable engine size
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
Re: Radical streetable engine size
28 Aug 2013 15:01
#603540
les holt wrote: I've seen the bike go mid 8's in street trim. Dot tire and no bar. Won't give details but seen flow #'s on the head which is a 900 head and know the all motor dyno numbers. Won't show a pic, it's a nasty sleeper.
Les
You big tease Les!
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
  • les holt
  • les holt's Avatar
  • Vendor
  • Vendor
28 Aug 2013 22:39
#603621
Tell ya what, come to Indy, bring cash, lots of it! and when it's all said and done, He might give a little insite! I do know this, it done lots of street battles around chicago in its prior life and it isn't pretty, just fast!!!
Les
  • geerbangr
  • geerbangr's Avatar Topic Author
29 Aug 2013 01:32
#603655
Sounds like a pretty serious grudge bike. 1500cc on the street . Can you say booooiiiinnnnggg !!!
1978 KZ 1000
I go by Jason
  • crh
  • crh's Avatar
  • Banned
  • Banned
29 Aug 2013 07:44 - 29 Aug 2013 07:58
#603678
les holt wrote: Bellucci head, turbo pistons. Went 219 all motor, won't say what on spray but its NASTY!
Les
219HP?
Dyno Jet Dyno?
Valve Sizes?
What was the peak HP RPM?
Carb Size?
A 1428 motor wants about 113CFM@10" to produce a potential 218 @8500. That's a trapped Ve of 125. Pretty stout ;) To get that takes an intake valve that requires over size seats. Not much sense in putting that kind of money in an old 900 head but hey...that's JMO. :)
Last edit: 29 Aug 2013 07:58 by crh.
  • Lorcan
  • Lorcan's Avatar
  • Speed Loony
29 Aug 2013 17:16
#603772
I assumed 219 meant MPH... :laugh:
760cc - 8.69@162mph
  • crh
  • crh's Avatar
  • Banned
  • Banned
29 Aug 2013 22:03
#603818
Lorcan wrote: I assumed 219 meant MPH... :laugh:
You may be correct but somehow I doubt an old unfaired Z is going to pull 219 MPH. If it does, I'm sure as hell impressed. Come to think of it if it makes 219 HP I'm impressed. Well done either way ;)
  • zukdave
  • zukdave's Avatar
29 Aug 2013 22:38
#603829
219mph on an unfaired KZ would take a
strong son of a bitch just to hang on to it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • geerbangr
30 Aug 2013 05:03 - 30 Aug 2013 05:08
#603888
Anyone running a 1428 on the street ? Also I see over at the kz zone they list a 1425 kit for use with the kz engine and the kz head then they list a 1428 kit for the kz engine with the J model head. What's the difference in the kz head and the J model head and which head is better ?
1978 KZ 1000
I go by Jason
Last edit: 30 Aug 2013 05:08 by geerbangr.
  • crh
  • crh's Avatar
  • Banned
  • Banned
30 Aug 2013 08:04
#603894
The difference is in the piston pin locations. Putting a J head on a KZ bottom end will reduce compression ratio. Therefore that has to be addressed.
J and GPz bathtub heads require less work to make power than a KZ head requires on a large cc motor.
I know an old piece of crap drag bike that will probably spew it's crankshaft all over the track sometime soon that runs 5.70's 1/8 mile steadily with less than .460 lift cams, small tire & bar, anciennt 38 trons, 1327cc, J head with 39/32 combo. The bike is old. The guy has no money....
Excessive heat and/or lack of lubrication are your motor's greatest enemies. Keep that in mind when you build you radical, streetable engine :)
  • geerbangr
30 Aug 2013 13:27
#603925
So is it better to invest the money in the KZ head because I already own one or get a J head and throw money at it What's the best bang for your buck. How about compression ratio, I don't see many talking about that. Ultra 94 Sunoco gas is about the best pump gas around. Where compression ratio do you start running into detonation issue with the KZ ? How about getting them started ?? Stock starter hold up to a 1327 or a 1428 ?
1978 KZ 1000
I go by Jason
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
30 Aug 2013 17:42
#603962
my stock starter would barely handle my 1327. It actually made my sprag unit go out. With a j model head you will lose right around 2 points of compression. If it was me i would get a j model head. But you do have to buy a idler adapter and the jig to locate the holes properly.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • geerbangr
30 Aug 2013 17:46
#603964
So how did you solve the starter issue powerstroke ?
1978 KZ 1000
I go by Jason
